Hey guys, thanks for recently letting me know a few things about the bigger style bellhousing. I have a question though.
I just found out the 164 tooth bellhousing is ment for going to an 11 inch clutch instead of the 10 inch clutch. well I have the 164 tooth flywheel and I have a 10 inch clutch, is that a problem? I am curiouse to how the pressure plate and the 10 inch clutch fits onto the 164 tooth flywheel,
one reason I ask if it's a problem is because ever since I have put in the tranny I have had a problem with first gear, when I take off I have to take off really slow, slower then any grandma would take off. or the whole car vibrates real bad. once I get going I can shift into second third and forth as fast as I want to with no problem. I was just assuming it was clutch chader, I have a new clutch and the flywheeel was reserfaced, so I thought I did something wrong on the install, so I took it to a shop here in town that did the rebuild for my trans, they took the tranny off looked at everything, put it back together and said I was good to go, but I still have the problem, could this be because I have miss matched parts.
Thanks
Ford Kid
Thanks
Ford Kid
