1970 Mustang Steering
Doug Gleason
I have a 70 fastback which I love. The power steering is egh. There is a lot of play in the steering wheel which seems pretty normal for vehicles around that time. My question is what good kits are there to tighten it all up.
Thanks!
check the back lash in the steering box ,it has probably never been adjusted .Rock the steering wheel back and forth and and have some one watch the pitman arm .If the wheel moves a lot and the pitman does not the back lash is loose .There is usually a lot of play in the valve assembly ,especially when the motor is not running ,it should be check for excess play when running .Check the idler for excess play the same as the steering box .
A borgeson steering box will cure all these problems problems ,except the idler arm,
