handymancanfixit Member Apr 10, 2025 35 10 18 Winston Salem, NC May 13, 2025 #1 May 13, 2025 #1 Anybody have the correct adjustment procedure for checking the timing and adjusting the carb on a 1984 GT 5.0? Much appreciated
limp wrap a little cheese around it and its a done 5 Year Member Oct 4, 2020 5,520 2,947 173 Florida May 13, 2025 #2 May 13, 2025 #2 Unplug your vacuum advance before you check timing... Make sure your idle is not too high Make sure you plug the vacuum advance back in when done.. Might want to check your vacuum advance can with a hand vacuum pump and make sure its working..
