1985 dashpot and kicker questions
Shelby69500
9
US
I currently have a stock 5.0 and carb in my 85 GT.
I need a new dashpot/kicker. There are three wires. Two go to the switch and one to the other.
Can I eliminate any of this on my carb?
Can I go to any mechanical without any issues on my computer?
I’m having to rebuild a junk harness in that area so I’m eliminating some wires if I can.
I have eliminated my AC.
My concern with that is what the early EEC will do without that device. My pre computer 302/5.0 ran fine without one with dealer AC and a Holley 1850-2. But if yours has a computer, at least the later ones are happier with the expected sensors. And I do not see reprogramming an early computer to be worth more than just putting the part in.
The dashpot may also help bring the idle up when coming to a stop if it's a 5 speed. It should be easy to adjust around.
If I remember correctly it is only used for ac on idle step up, can't remember it being tied into the cold start choke, if it is and you take it off you may have to hold the throttle open a little for a minute or two for cold start.
