Engine 1986 Mustang Only Starts Cold, Suggestions?
odsysean
40
Pa
Okay so I have a 1986 Mustang lx vert that I bought as a project car about a half a year ago. The main problem was that it ran like crap and didn't stay running when first purchased. So far, things I have tested/replaced were:
1. Spark plugs and spark plug wires. (Brand new)
2. Distributor cap and rotor. (Brand new)
3. Ignition coil. (Brand new)
4. TFI Module and pick-up coil. (Brand new)
5. EGR valve. (Used off other 86' Mustang but functions properly)
6. All new vacuum lines (dry-rotted)
7. PCV valve, grommet and filter (Brand new)
8. 8 OEM 19#hr Fuel injectors (Brand new)
9. Fuel pressure regulator (Brand new)
10. Fuel filter (Brand new but ran a small amt. of old gas diluted with 91 octane)
11. IAC valve (Used off other 86' mustang/not sure if functioning properly)
12. Reverse light switch (Brand new)
13. Has no cats but still has two o2 sensors in off-road h-pipe (Had when purchased)
14. Heater core (brand new)
15. Brand new front fenders
16. Brand new front bumper
17. Brand new Harwood 2in. cowl induction hood
I also tested for electrolysis in the cooling system: voltage was less than .10 volts (Nothing to worry about)
Things i'm thinking on checking/fixing/replacing:
1. Ignition solenoid
2. Starter
3. Fuel pump
4. Fuel pump relay
5. Carbon canister
6. Speedometer gear/cable (stock 2.73 gearing, 7t drive gear/16t speedo. gear?)
My problem is that it only starts when cold. When it starts cold, it seems to idle decently, but it runs quite rich. It hesitates and backfires when accelerating more than normal. Sometimes it stalls when coasting in neutral. This is actually my first car and I go to automotive school and I pay peopl to take me when I rather drive myself. The car isn't in bad shape (minimal rust, straight frame, old worn down top, cosmestic stuff. The passenger compartment has wires and such dangling from the dash, but all are connected properly. I have come down to this and now i'm stumped, my knowledge is limited. If anyone would be so kind and help me out, i'd much appreciate your time and effort! Also, I'll try to help you as well in the future.
When it's warm and won't start, do the checklist....
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 12-Dec-2011 to replace 10 pin salt & pepper connector graphic.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
salt-pepper-10-pin-connectors-65-jpg.68512
The injector power pin is the VPWR pin in the black 10 pin connector.
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
The conversion is simple jrichker has all the info you will need im sure he will post it soon.
Do you have vac to the Baro sensor? In a speed density car it gets vac, With the mass air it does not.
No, if i could find the conversion, i'd do it
Fix your current round of problems before doing anything that could add or hide other problems. Once you get the car running good in it's current state, you can do a Mass Air conversion. Then you will know that if there are problems, it's in the conversion and not something you skipped fixing earlier. Doing it this way shortens the problem list of things you need to check and sort through.
Reactions: 88LX5.Oh
Does it crank but not fire when it's cold, or does it not even crank? I had a problem with my car where it would only start cold, and when it was hot the starter was unable to achieve much more than about half a revolution of the engine. Turned out it was a bad ground. I ran a ground wire to the starter bolt going into the bellhousing and it made a day and night difference.
As far as i'm sure, everything other than the HFC134a retrofit and offroad h pipe with 40s series mufflers, the motor is all original. I just did the tuneup and circuit testing on a few things and referred to chiltonPRO. So i think the speed density setup is all there, im not sure what a baro sensor is yet -.- however, on a cold start, it runs fine if i baby it, i cannot bang gears especially since the 1-2nd syncros are bad (grinds even when clutch is floored and shifting normally) but every other gear is more than fine. I stopped to fill it up and it turned over fine, just a little more sluggish than the cold start would. It just doesn't fire up. a ford specialist teacher of mine told me it sounded like a worn out tfi module so i just changed it since it doesnt cost a fortune, and as i changed that i changed the little pickup coil. still no start. at this point i had 4 new injectors on cylinders 5,6,7, and 8. just this past weekend i changed the other 4 injectors hoping maybe they were clogged and really bad (which they were) since they looked old and grimed over. i blew out the fuel rail with gum cutter and dried it with compressed air, so the rails are fine, just a couple specs of surface rust. when i checked the fpr, it read 18psi so i changed that as it only cost me about $20 and it was just old and i supposed it was faulty. when i checked the new one, it was set at about 40psi. so its getting gas. the injector wires read 12v (im almost positive). when i pulled the plugs the first time, they were so nasty and fouled. so i changed the whole pcv system and changed the oil since it was gas contaminated (flooding). i did a compression test and each cylinder read 120-125psi except one that read 118 psi (dont think that has too much affect). the only thing i didnt check was the starter and solenoid. i thought maybe they were heat soaked from the headers but it seemed to crank fine when cold just a little sluggish when warm. this is really starting to bum me out, im running out of knowledge, i didnt check the battery ground but i assumed it was fine, ill check that next time i can and do a voltage drop on the starter, battery, and relay. could it be that one device dangling under the glove compartment that is upside down when it specifically states a certain side up? i dont know what it is, but i remember reading "this side up" or similar on it.
it cranks OK when warm, but no start
Then when the engine is warm and does not start, do the "Cranks OK but No start" checklist. It has worked for more people than I can keep up with. It will save you time and money by eliminating the things that do work from the list of problem causers. Using simple diagnostic tests and coming up with a short list of potential trouble causers is a lot easier than working with a long list .
