1988 GT Drivability Issues..Knowledge needed please.
gearheadboy
1,425
177
84
Greencastle Pa
Hello. Let me start with what I HAVE and what it DOES.
I have a 1988 GT factory California mass air automatic car. It has been converted to a T5 and it all seems to be done properly. (I have had it all out and rebuilt the trans). I replaced the 1988 mass air computer with an A9P which is a newer automatic unit. The car has a BBK SSI intake and 70mm throttle body. Factory fuel pressure regulator making the correct pressure. (39 at idle, 45 or something with the vacuum line unhooked). I have replaced the IAC, coolant temp sensor, and Intake air charge temp sensor. The car has the factory 1988 mass air sensor on a C&L 76mm tube with the 19lb injector sample tube. It has stock orange top injectors. I have sprayed carb cleaner everywhere and been all over the thing looking for vacuum leaks, nothing found. The TPS is set at .77 volts. No codes except for the A.I.R. system which is gone.
What it does: The car runs good warm. Cold start, it starts, idles up, comes down and stalls. I restart it and it will start and idle up and then settle down to about 800 rpm and be uneasy until it warms up. Usually only stalls once, sometimes twice. The exhaust stinks rich a little bit but not smoking black. If I try to take off I can drive it however it stumbles and acts dumb until it warms up.
What I'm wondering is, do I have a junk MAF ? or is it a crap design and need a better after market tube, or is it the wrong size? Any ideas? Questions? It runs better with this newer computer but I've had this car 2yrs and it has been cold blooded since I bought it. Nothing has helped other than the computer.
Seems to me the T/P voltage should be under 1 volt KOEO and over .9 volt KOEO. What is the ignition timing set to (spout disconnected). I have also seen cold start and engine dying issues due to plugged fuel filters/weak fuel pump. Without actually seeing it in action, those are my first best guesses. How you describe the problem, and how i (or others) interpret them can cause some miss-diagnosis. Do you have a stock MAF to try? Some C/L meters are not so accurate depending on application.
Thanks for the reply. I have read conflicting things about the TPS voltage. I will say it is a new TPS, Because of the arrangement with the throttle body and intake, I need to clearance the outside of the sensor a bit to get more adjustment, but have not because I read that >than like .65volts TPS really doesn't matter because the computer just learns it as a base line. I don't know. I DO have a stock MAF and that is where I am headed, however on an 88 factory California car the MAF connector is different than an 89-93. So I have to buy a connector to make it work. I suppose I could swap out the meter and reuse my electronics to rule out the tube. I'm leanin toward the sensor since it is the factory 1988 unit. The base time has been reset to 14 degrees with the spout out.
The best way to describe it is after it sits all night or till cold (summer or winter), I start it, it starts normal, runs at about 1k to 1200 rpm for a few seconds and then stalls. Without touching the throttle, I restart it. It goes to 1k to 1200 rpm for a few seconds then comes down to 850 runs kinda unstable and either stalls, or continues unstable and hangs on by a thread till it starts to warm up and becomes more stable. It does NOT do the idle up and down searching thing. I replaced the air charge sensor a few weeks back and that seemed to make it more rich cold and kept it from stalling the second time now, where as it did stall at least two times before. If I back it out of the garage I can drive it if I want, but I have to feather the throttle to keep it from falling on its face. If I throttle normally it stumbles and acts lean until warm. Kinda like a cold blooded engine with a holley and no choke. I'm a skilled tech but I bought this car this way and it runs worse than any of the 5.0L Mustangs I have ever owned. Once it is warm it runs fine. The exhaust does smell a bit but no black smoke and no cats. I have bought a fuel filter which I never installed yet. Fuel pressure is good. Volume? I'm not sure.
See the "Surging Idle Checklist” for help with all your idle/stall problems. You can guess at the problem and throw parts at it, or you can use the checklist to help you find the problem quickly and inexpensively.
The quick and easy way to dump the codes is in there too, and all you need to do it is a paper clip! The first two posts contain all the fixes & updates. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
A bad or missing Baro Sensor should set code 22.
MAP/BARO sensor operation and code 22
Revised 19-Jul-2011 to add functional descriptions for MAP and BARO operation.
On a Speed Density car, the MAP/BARO sensor is connected to the intake manifold and acts to sense the manifold pressure. Lower vacuum inside the intake manifold when combined with more throttle opening measured by the TPS means more airflow through the engine. As airflow increases, fuel flow through the injectors needs to increase to keep the air/fuel ratio where it needs to be. When manifold vacuum increases, the engine is either decelerating or idling, and it needs to reduce the fuel flow through the injectors.
On a Mass Air car, the MAP/BARO sensor vents to open air and actually acts to sense the barometric pressure due to changes in weather and altitude. Its purpose is to set a baseline for the computer to know the barometric pressure. As barometric pressure decreases, it leans out the fuel flow to compensate for less oxygen in the air. When the barometric pressure rises, it increases to add fuel since there is more oxygen in the air. The fuel requirements decrease as altitude increases, since the atmospheric pressure decreases.
Disconnecting the MAP or BARO sensor will set code 22.
Misconnecting the BARO sensor to vacuum on a Mass Air car will cause the computer to lean out the fuel mixture.
Code 22 or 126 MAP (vacuum) or BARO signal out of range. The MAP or BARO sensor is pretty much the same sensor for both Mass Air & Speed Density cars. The main difference is where it is connected. Mass Air cars vent it to the atmosphere, while Speed Density cars connect it to the intake manifold vacuum. Its purpose is to help set a baseline for the air/fuel mixture by sensing changes in barometric pressure. The MAP or BAP sensor puts out a 5 volt square wave that changes frequency with variations in atmospheric pressure. The base is 154 HZ at 29.92" of mercury - dry sunny day at sea level, about 68-72 degrees. You need an oscilloscope or frequency meter to measure it. There a very few DVM’s with a price tag under $40 that will measure frequency, but there are some out there.
The MAP/BARO sensor is mounted on the firewall behind the upper manifold on 86-93 Mustangs.
Baro or MAP test using frequency meter - run the test key on engine off. The noise from the ignition system will likely upset the frequency meter. I used a 10 x oscilloscope probe connected from the frequency meter to the MAP/BAP to reduce the jitter in the meter's readout.
If it is defective, your air/fuel ratio will be off and the car’s performance & emissions will suffer
Some basic checks you can make to be sure that the sensor is getting power & ground:
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter.
Check the resistance between the black/white wire on the MAP/BARO sensor and then the black/white wire on the EGR and the same wire on the TPS. It should be less than 1 ohm. Next check the resistance between the black/white wire and the negative battery cable. It should be less than 1.5 ohm.
The following power on check requires you to turn the ignition switch to the Run position.
Use a DVM to check for 5 volts on the orange/white wire. If it is missing, look for +5 volts at the orange/white wire on the TPS or EGR sensors. Use the black/white wire for the ground for the DVM.
