1992 5.0 Help!
  • Thread starter Thread starter 92WMR
  • Start date Start date Apr 9, 2017
9
92WMR
  • Apr 9, 2017
Hey y'all, I just bought a new(to me) fox body! So I've gotta button up a few things to get her going.. She needs heater hoses, all coolant hoses installed, fuel lines, trans lines.. Ive got a question though.. with the intake it has a BBK EGR spacer... if I'm running a egr block off plate do i still need to run this spacer? Im new to the mustang world.. any help would be appreciated!!
wgreenlee4
27
Apr 9, 2017
  • Apr 9, 2017
People usually run the spacer either to 1-separate the hot lower intake manifold, 2-fit larger valve covers, 3-block off egr there if the spacer doesn't have an egr hole cut in the center.
So I guess I'd take a look if you have larger valve covers. But it's nice to have so I don't know why you'd want to remove.
D
Deleted member 215073
Apr 9, 2017
  • Apr 9, 2017
I think he means the EGR spacer between the throttle body and intake. Leave the EGR stuff on the car, it doesn't hurt horsepower, and the computer changes fuel strategies under cruising loads.
Reactions: jrichker
General karthief
Mod Dude
Aug 25, 2016
28,133
10,750
213
polk county florida
Apr 9, 2017
  • Apr 9, 2017
I think the egr spacer has the throttle bracket mounting holes on it right?
9
92WMR
  • Apr 9, 2017
yes it bolts to the upper manifold, yes number 51 is correct. On mine there are two tubes that run off it, the back side (fire wall side) i believe runs to the egr valve from pictures I've seen on the internet.. or does it not? can someone trace theirs and find where it leads?
Edit: (See pic below) where the little red caps are.. the front one goes to a hose thats just below it.. where does the back side one connect to?
9
92WMR
  • Apr 9, 2017
This is how she sits right now.. still needs some love
General karthief
Mod Dude
Aug 25, 2016
28,133
10,750
213
polk county florida
Apr 9, 2017
  • Apr 9, 2017
There is a nipple in the lower intake (stock) water jacket at the back corner, may not be there on aftermarket intakes, it's for water to circulate inside the egr spacer, depending on where you live and temps you drive in as to if you need it.
9
92WMR
  • Apr 9, 2017
so if i don't have the nipple on the intake do i just run w/o it? leave it empty
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,953
5,831
213
Apr 9, 2017
  • Apr 9, 2017
The one in the back coming off the spacer between the TB and the upper intake should go to a fitting that's screwed into the block.
General karthief
Mod Dude
Aug 25, 2016
28,133
10,750
213
polk county florida
Apr 9, 2017
#10
  • Apr 9, 2017
  • #10
You can run without it, unless you live and drive in sub freezing temps.
90sickfox
Mar 2, 2015
6,953
5,831
213
Apr 9, 2017
#11
  • Apr 9, 2017
  • #11
You can run without it...a lot of people use the spot in the intake for a temp gauge and use a bolt and clamp to plug the front hose.
D
Apr 9, 2017
#12
  • Apr 9, 2017
  • #12
As far as sub freezing temps, didn't the 1993 Cobra also not run coolant through the EGR spacer? If so, couldn't a person also not run the coolant lines and be fine?
General karthief
Mod Dude
Aug 25, 2016
28,133
10,750
213
polk county florida
Apr 9, 2017
#13
  • Apr 9, 2017
  • #13
Yes
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Apr 9, 2017
#14
  • Apr 9, 2017
  • #14
look on Ebay for an EGR delete plate that is the same size opening as your Throttle Body..
General karthief
Mod Dude
Aug 25, 2016
28,133
10,750
213
polk county florida
Apr 9, 2017
#15
  • Apr 9, 2017
  • #15
Ok, the cobra intake I have has a nipple and from a pic I found online its for water from the heater tube, I don't see where it exits. So they are built into the upper intake.
5.0specialist
141
53
48
venice fl
Apr 16, 2017
#16
  • Apr 16, 2017
  • #16
It is actually there to keep the EGR spacer cool. Hot exhaust gas passes through there when the EGR is activated and the engine coolant keeps it from getting as hot as the exhaust gas. Basically, if you have a functional EGR, leave it or reinstall the EGR spacer coolant hoses.
Reactions: General karthief
General karthief
Mod Dude
Aug 25, 2016
28,133
10,750
213
polk county florida
Apr 16, 2017
#17
  • Apr 16, 2017
  • #17
Thanks there 5.0, I get dyslexic sometimes, been working on a chrysler mini van, makes me want to run out and hug my cobra intake
Reactions: 5.0specialist
5.0specialist
141
53
48
venice fl
Apr 16, 2017
#18
  • Apr 16, 2017
  • #18
lol No problem. Now go hug your stang.
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Saying Hi
  • BriansNSane
  • Dec 20, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 21, 2025
BriansNSane
M
Engine Help identifying part# small ID molded heater hose
  • mads
  • Mar 23, 2025
Fox 5.0 Mustang Tech Mar 23, 2025
mads
M
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
