1993 GT will not start
  • Thread starter Thread starter Poorboyz
  • Start date Start date Jun 2, 2010
P
Poorboyz
  • Jun 2, 2010
I'm having I believe a common problem with my mustang. I went to redo my whole a/c system including the Evaporator which I had to take out the dash for and once I put everything back the car will not start. I've done a lot of research on here but I guess I have not found my problem.
I've used all these plus some others as reference.
http://www.stangnet.com/mustang-forums/756930-car-wont-start.html
http://www.stangnet.com/mustang-forums/814372-no-power-red-green-wire-ecc-power-relay.html
93 EEC Relay - MustangForums.com
My fuel pump runs continuos, will not stop running. I have no power at the fuel injector wires...I have constant power when I turn on the ignition, but once I try starting the car I get no pulse signal. I have verified power to the EEC relay above the ECM and I'm getting 12v there. I have changed out the fuel pump, verified power to the inertia switch in the trunk. I'm also not getting power to the TPS. I have verified that all the wires around the ignition are snug in the connector.
The car ran great with no problem before this and hopefully it will continue to run great once I get this figured out with help. I have tried averything I know to do and also things from the info on this site.
Thanks
Chuck
P
Poorboyz
  • Jun 3, 2010
Bump
Anyone? The car has been sitting in my garage since Saturday and I've tried everything I know.
Thanks
P
Poorboyz
  • Jun 4, 2010
Nobody has any insight on this matter??? WOW
HISSIN50
34
129
Jun 4, 2010
  • Jun 4, 2010
If the TPS sees above ~3.71 V, it shuts off ground to the injectors (thus, they will not excite). If you can get the TPS squared away, it might fix the injector issue. You said you don't see VREF at the TPS (5.0V). Does the return show any voltage?
I'd re-run the checklist. It will save time and money.
Good luck.
P
Poorboyz
  • Jun 5, 2010
I'm using a analog meter and it looks like I'm getting somewhere between 1 and 1.5 volts at the orange wire on the TPS. I'm testing it using the orange and black wire on the TPS with key on at closed throttle. I'm about to give upon this thing.
P
Poorboyz
  • Jun 5, 2010
Got it fixed. Car is running. Found someone that had a spare ECM and they came over and we plugged the new ecm in and the car started right up. BAD ECM
Thanks HISSIN50 for your help.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
D
1989 mustang 5.0 crank no start
  • Darkstang302
  • Tuesday at 3:24 PM
Fox 5.0 Mustang Tech Yesterday at 4:42 PM
AeroCoupe
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
