1994 Ford Mustang Drag Car 2010 Points Champ!
cory94stang
I have a 1994 Ford Mustang GT for sale it is the Thunder Valley Dragways 2010 Pro Trophy track champion and I bought a different car so this one has to go. The fastest the car has ran is a 10.44 at 129mph on a perfect cool night with a 1.38 60ft but it usually runs a very consistent 10.60s. I can usually put a number on in the morning and leave it on the rest of the day. The car has a 410ci Windsor with 4340 eagle crank and eagle 4340 H-beam rods, Mahle pistons it is a sporstmans block and I also had 4bolt mains put in as well so it is very strong. It has AFR 205 heads with stud girdles. Cometic head gaskets and It has a mechanical roller howards cam 300/314 664/656, Victor Jr intake and a Mighty demon 750cfm carb. Fluidyne aluminum radiator and CSR electric water pump. It has a C-4 trans with Precision industries 4000 stall converter, tci transbrake valve body with reverse shift pattern, tci transmission blast shield, 6 pinion planetary and built right. It has a B&M hammer shifter that I absolutely love. The rear end is a ford 8.8 with solid spool and ford racing 4.10 gears with strange 31 spline axles and longer wheel studs,28x11.5x15 MT tires in the rear. The front has tubular a-arms and coilovers. It has sub frame connectors and a roll bar. The rear suspension is aftermarket not sure on the brand because it was done by previous owner and I also added a rear air bag. It has an 8 gallon fuel cell, a new optimum battery. The interior is stripped but done right with a back seat delete kit and looks very nice just so many things I could go on all day.
Contact me on my cell at 605-660-3965 or
[email protected]
$13,000 obo
