1994 mustang seats in fox
The back seat will work but you have to take the guts from the fox seat and the SN seat and put the SN over the fox guts, takes a little trimming in the corner to let the seat cushion pull over the fox backing. The front seat wiring is simple, I just used a small peice of wire with two female slide connectors on it and went off the fox plug positive and negative and went into the seat. The factory plugs on the fox chassis harness and the seat are both female sockets so they wont plug in but the little extensions will allow you to make it work without cutting the plugs off.
