ac
NOTE: The evaporator core orifice is an integral part of the condenser to evaporator line and should be installed as an assembly with the line.
NOTE: A new evaporator core orifice should be installed whenever a new A/C compressor is installed.
Item Part Number Description
1 19E561 A/C cycling switch
2 19D701 A/C charge port valve (low side)
3 19D594 Refrigerant containment switch (3.8L vehicles)
3 19D594 Dual-function pressure switch (4.6L vehicles)
4 19D734 A/C manifold and tube
5 19D644 A/C compressor pressure relief valve
6 19703 A/C compressor
7 19D701 A/C charge port valve (high side)
8 19712 A/C condenser core
9 19835 Condenser to evaporator tube
10 19C836 Suction accumulator
11 — A/C evaporator core (part of 19850 assembly)
