  • 1994 - 1995 Specific Tech
2.05 valve on twested wedge !!!
  • Thread starter Thread starter 94stang-lover
  • Start date Start date Apr 16, 2005
9
94stang-lover
62
  • Apr 16, 2005
anyone upgrade the twisted wedge valve from 2.02 to 2.05. i need to know if i need to change the valve seat or not ?? if yes what seats did u use and if u recommend any specific valve ?!?!
thanks
9
94stang-lover
62
  • Apr 16, 2005
anyone ?!?! i just need to know if i need differant seats than the one's i have ?!?
T
TMC
1,426
Chicago
Apr 16, 2005
  • Apr 16, 2005
I would think you could use the stock seat but I don't see a need for a larger valve unless your trying to make BIG power. The larger valves may not even help make more power. Why are you looking to go with that valve?
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Apr 16, 2005
  • Apr 16, 2005
are you nuts? The 2.02 valves sit pretty damn close to the 1.6 exhaust valves. I wouldnt touch them at all. Besides, the heads flow nicely allready, and likehe said, I wouldnt change them unless you're wanting big power...
9
94stang-lover
62
  • Apr 17, 2005
i forgot to mention i just finish my 347 short block with 10.5 compression. that’s y i'm looking to upgrade the heads. i know the intake and exhaust valves are damn close but is it possible to change them or not ?!?!
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 17, 2005
  • Apr 17, 2005
Yes you can put a 2.05 valve in them and yes it requires machine work. As long as you have the p to v clearence and a custom grind cam to take advantage of it, you should be fine.
I thought about doing that to my TW heads for my 347, but i'm keeping them as is. I told Ed what I had and what I wanted and he grinded me up a pretty aggressive cam. Motor isn't finished yet but I just found out my cam specs today.
T
TMC
1,426
Chicago
Apr 17, 2005
  • Apr 17, 2005
If that is the only reason you are looking to put the 2.05's in there than I wouldn't worry about it and just run the 2.02's. Minimal to no gain with the larger valves. You would be better off spending your money somewhere else.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
