2.73 rear gear
  • Thread starter Thread starter hsean
  • Start date Start date Apr 22, 2011
1 of 2 Next Last
hsean
656
69
69
dearborn,michigan
Apr 22, 2011
  • Apr 22, 2011
i bought this 96 mustang rear end last year and got to cleaning it up.i looked inside and sure enough its a 2.73 .what can i expect for a shop to charge for an upgrade to 3.27 or 3.55?is 2.73 really that bad?my car will be basically a nice driver .the motor is stock and i am getting ready to change the fluids and throw the suspension stuff back on.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 22, 2011
  • Apr 22, 2011
2.73's aren't "that bad", but a steeper gear is a great upgrade for performance on an otherwise stock car. If the car is a stick, I'd be thinking about 3.55 or 3.73. It it's an AT, then 3.73 or 4.10. Prices vary WIDELY. I've heard of guys getting them done from $2-300 all the way up to $1000+.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
Apr 22, 2011
  • Apr 22, 2011
I paid $175 for my install...but this was back in 2000
2.73's are what most fox mustangs have anyway stock..not the end of the world. I prefer the low gearing. Just make up for it in HP!
hsean
656
69
69
dearborn,michigan
Apr 22, 2011
  • Apr 22, 2011
way back in 1987 i bought a white gt with an automatic and 2.73 gear in the back off the lot and it was a dog.then i ordered an 90 lx with the 3.08 but considerably faster but it was a 5speed car, i got to enjoy it for 8 months before it was stolen.i am disappointed because i was ready to reinstall everything this weekend and i was told by the guy that i bought this from that it had a 3.27 gear in it.i only paid 120 for the whole rear end so atleast it is an 8.8 rear.i am on the fence right now i don't want any problems with it just would like to spend my money elsewhere right now.there is a benefit to the 2.73 being that gas prices are going up and it will be cheaper to drive with my leadfoot.i am not going to do anything with it this weekend.i am going to give it a week but i think i'll just throw a 3.55 in it.i'm going to start calling around these reputable axle shops .
Mintsick
589
39
68
West Lafayette, IN
Apr 22, 2011
  • Apr 22, 2011
Realistically if it's just a straight gear swap without a trac-lok rebuild I'd expect to pay $250-400.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
Apr 22, 2011
  • Apr 22, 2011
Might be cheaper to bring the axle to the shop as is for the gear change...vs bringing a car.
I'd imagine doing it on a bench would be simplier
hsean
656
69
69
dearborn,michigan
Apr 22, 2011
  • Apr 22, 2011
just called a performance shop and they had a used 3.73 for 95 bucks and what they consider reasonable was 300bucks and that was without having to change out bearings.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Apr 23, 2011
  • Apr 23, 2011
do a little research and tackle it yourself
gear changes are pretty simple if you know what youre doing. Setting preloads and turning tq can get a little complicated if its your first time but its definitely worth learning how to do. Then you can charge other people ridiculous amounts to swap a ring and pinion.
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Apr 23, 2011
  • Apr 23, 2011
Actually i've been told different that it's harder to do on a bench. Didn't ask the reasons why, but i'm guessing it has to do with it moving around and getting the torque settings right.
hsean, i know this is not what you are going to want to hear, but since it's a used rear, you are going to want to overhaul the whole thing while it's apart.
Rebuild the trac lok and all new bearings.
Makes no sense to do it twice.
And since i'm guessing you plan on using this rear in your fox, take into consideration your wheel choice, because the wider rears don't like all wheels.
hsean
656
69
69
dearborn,michigan
Apr 23, 2011
#10
  • Apr 23, 2011
  • #10
thanks for the heads up ,i just picked up a 3.27 gear for it so it looks like i am going to do the upgrade.i had 17x9 oem 2003 cobra wheels but i traded for polished 99 cobras so i should be alright there.
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Apr 23, 2011
#11
  • Apr 23, 2011
  • #11
I know this is going to sound very negative, but 3.27's aren't worth the effort over 2.73's. One set just sucks less, that's why people damn near give 3.27's away.
3.55's is the minimum that's worth the trouble, me personally i wouldn't bother for anything less than 3.73's.
Mintsick
589
39
68
West Lafayette, IN
Apr 23, 2011
#12
  • Apr 23, 2011
  • #12
While I don't think I would spend the money swapping 2.73 to 3.27 I think there still will be a noticeable difference between the 2. I had a 5spd pickup that I swapped the stock 3.08's for 3.42's and I was pretty happy with the improvement.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
Apr 23, 2011
#13
  • Apr 23, 2011
  • #13
It's all personal preference really.
I hate my 3.73's and am considering installing 3.27s instead.
hsean
656
69
69
dearborn,michigan
Apr 23, 2011
#14
  • Apr 23, 2011
  • #14
I did the rpm calculator over on corral and for my application I felt it was ideal.I sold a 3.55 I had laying around in the garage a few months ago.
hsean
656
69
69
dearborn,michigan
Apr 23, 2011
#15
  • Apr 23, 2011
  • #15
I practically gave a set of 3.55 away a few months ago .lol I have a friend with a nice capri at work and he loves the 3.27 gear in his car.he has had all the gears through the years and says its a nice gear for a driver.I did the rpm calculator over at the corral and doing 80 miles an hour still pretty low rpms.I do plan on making some trips out of state with it when its done.
Rick 91GT
Mustang Master
95
99
PA
Apr 23, 2011
#16
  • Apr 23, 2011
  • #16
I just want to add my $.02...if your using used gears it is important to install them back at the same depth or they could make noise. I mark all the gears with a paint marker when I install or remove them
For a straight gear swap I charge $250 which includes fluid. Like XP stated id also suggest a full rebuild if you plan to keep the car and you have high mileage...makes a huge difference. I also would go 3:55-3:73
Kdubslugga
1,515
Akron, OH
Apr 23, 2011
#17
  • Apr 23, 2011
  • #17
I paid 450 for a gear install after the shop told me they would do it for 200. I have never had anyone work on any of my cars other than me since then, and Ive done gears like 3 times, and its really not that hard at all! And just an fyi. I used to have a 90 LX AOD that ran 14.7s.I swapped from 2.73s to 4.10s and ran 13.9 with nothing else done!
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Apr 23, 2011
#18
  • Apr 23, 2011
  • #18
Yup, the difference in how long your rear lasts is using good parts, qualified labor and being thorough.
You could put used gears in a used rear and have it be worthless in 6 months.
Or you could do a complete job and have it last 100,000 miles.
hsean, from your description of the 5th gear rpm i'll guess you are going to drive alot or this is a daily driver.
While you may notice a little less mileage on the highway with 3.73's, they are also known for better mileage around town.
Regardless of your gear choice, rebuild the thing top to bottom, or it's likely you will be back complaining of gear whine, the one wheel peel or even worse your axle bearings could go and permanently wear down your axles. (and yes i've had this happen)
Do it once, and do it right.
hsean
656
69
69
dearborn,michigan
Apr 23, 2011
#19
  • Apr 23, 2011
  • #19
Thanks for all the replies fellas I definitely want to do this right that's why I am taking it to someone that does this for a living.I am going to have him go through it all and replace the bearings as well.yes I will be driving this thing when its done.I plan on putting the mileage on it and in the future a new 5.0 swap.
2000xp8
Aug 8, 2003
8,078
1,659
194
NJ
Apr 23, 2011
#20
  • Apr 23, 2011
  • #20
Don't forget the carbon clutch rebuild kit.
1 of 2 Next Last
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
G
Expired 2013 Ford Mustang V6 (Grabber Blue) 3:55 gears... Excellent Condition.
  • Grabberblueguy77
  • Nov 19, 2025
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Mar 11, 2026
Grabberblueguy77
G
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
