2 oil drain plugs?
ACSPONY
Oct 10, 2004
711
Ohio
I had no idea the 5.0s had two oil drain plugs. I only removed the rear plug when I did my oil today, seemed to all come out... Is this a problem? I didn't even see the other plug, although I wasn't really looking for it.:shrug:
Some of the dipsticks were mismarked at the factory.
ACSPONY, I'd do a shorter interval on this oil (if it wasn't something expensive) personally.
Good luck.
Good luck.
I'll be driving the car this summer mostly on the weekends and probably won't put too many miles on before I go back to school so I'll change it before I go back.
i really believe ive been running a quart low for a long long time then....i just changed it and put all 5 in...its a bit high. i thought there was just more oil in the pan somewhere before....because i use ramps. surely didnt really want to overfill
