2 quick problems
  • Thread starter Thread starter 1.8kmint
  • Start date Start date Jun 2, 2007
1.8kmint
47
Middletown, CA
Jun 2, 2007
  • Jun 2, 2007
Ok I have a 1992 lx 5.0 and 2 little problems. First something is wrong with the vents in my air conditioning and defroster because when i turn on the air it comes out the defroster and speakers instead of through the vents, (air conditioning does blow cold and heater warm) It just comes out the defroster for some reason. Possibly a minor electrical problem or piece of plastic behind the dash. If someone knows the best way to take the dash off and check for a problem like this it would be helpful. Second I'm having trouble finding a wheel cap cover for my rims to cover up the 4 lugs. I can find them in chrome and metal but all i need is one little plastic cover(ima repaint it anyways). Wheels look like this i just need that center cover.
http://img124.imageshack.us/img124/350/mustangwheelcapsh4.png
If any1 knows where can order one for cheap online that would be appreciated. Thanks
Fett
766
  • Jun 2, 2007
Look behind the dash down on the drivers side of the radio, you will see a vac actuator, this moves the air flow door. The vac line running to it is broken somewhere.
Actually, first open the hood and look on the firewall near the pass side of the car, next to the accumulator. There is a thin vac line coming out of the fire wall and going into the vac canister in the fender. I bet that line is broken. That is the cause for your vent issue.
jtfairlane
468
  • Jun 2, 2007
I second this, totally. Double check this BEFORE doing anything like pulling the dash apart. I had the similar issues as you, and found a simple busted vacuum line in the engine bay, spliced it back together with vacuum hose, and bingo, defrost/heat/ac worked properly again.
1.8kmint
47
Middletown, CA
Jun 2, 2007
  • Jun 2, 2007
Perfect you guys are great. Sure as you expected the line was cut just before goin into the inside of the car. Put some electrical tape on it and it was running fine again. Thanks alot guys. Now just need to find a wheel cover and I'll be good to go.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Resolved Needing some guidance on the A/C vacuum lines again
  • mikeah
  • Feb 12, 2024
6K
Fox 5.0 Mustang Tech Aug 21, 2024
alutwon
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
M
  • mnky99
  • Sep 5, 2025
mnky99
M
