2001 mustang won’t crank
bstegall20
Tupelo,Ms
my 01 mustang has some sort of starting problem if it sits for a while it’ll start up but as soon as i turn it off and try it again i get nothing so i basically can only crank it like once a day but i found out i could start it from the starter with a screwdriver so i thought the starter was bad . replaced the starter and i get the same problem i also replaced the ignition switch . any thoughts before i go spend money at a shop ?
Automatic or manual?
What have you done to trouble shoot the neutral safety circuit?
Confirm there's key in crank position in and out of fuse F2.6.
1999-2004 MY fuse panel schedule:
+1 on swapping the starter relay with another working relay.
