okay recently hit with minus degree weather and suddenly the horn is no longer working when you double click lock button, next gauges aren't reading correctly, speedo not working. rpm gauge not working. gauge needles jumping to max and then bottoming out. also doing same when brake peddle pushed. this also cuts out radio. now car is dead nothing turns on off.. assuming battery is dead and alt not working can a bad alternator cause these problems?
