  • SN95 4.6L Mustang Tech
Resolved 2004 Mach 1 WOT fuel/spark issue?
  • Thread starter Thread starter gavinmgrant
  • Start date Start date Jan 12, 2023
  • Tags Tags
    fuel mach 1 misfire
First Prev 2 of 2
gavinmgrant
51
Texas
Feb 14, 2023
#21
  • Feb 14, 2023
  • #21
Shuttleman83 said:
There is a ground to the ECU I have taken that off before and cleaned it, also, you could try this.
Try disconnecting the negative battery terminal for 2-4 hours then letting the car do a full re learn. Don't mess with any adjustment screws or idle screws.
The ground is good, I double verified after your comment. Reads less than an ohm. I have tried leaving the battery disconnected for days at a time before. No change. I disconnected the gauge cluster to rule out the gauge cluster possibly having some sort of short (I have PATS deleted so it will still run) and watched the RPM through my SCT X4. Still had the same rev limiter problem when it hit 5k. I think I am now dead set on a new PCM.
Shuttleman83
239
USA
Feb 14, 2023
#22
  • Feb 14, 2023
  • #22
Check the throttle body and the throttle cable, maybe something is binding or the throttle body isn't opening as wide as you think?
gavinmgrant
51
Texas
Mar 6, 2023
#23
  • Mar 6, 2023
  • #23
Update: New PCM fixed the issue. Runs amazing now.
Shuttleman83
239
USA
Mar 7, 2023
#24
  • Mar 7, 2023
  • #24
Had a feeling, good to know it's fixed.
gavinmgrant
51
Texas
Mar 7, 2023
#25
  • Mar 7, 2023
  • #25
Same. What a pain. Just about done with tuning the car. It runs amazing now. Onto the next thing
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jul 8, 2023
#26
  • Jul 8, 2023
  • #26
gavinmgrant said:
That’s what I’m thinking too.
Any luck yet on finding the issue?
gavinmgrant
51
Texas
Jul 8, 2023
#27
  • Jul 8, 2023
  • #27
It was a bad PCM.
First Prev 2 of 2
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
