Expired 2005-2009 Mustang Steeda Tubular Upper 3rd Link Control Arms $80 shipped
israel torres
Steeda's upper control arms feature a unique bushing design combined with a sturdy steel tube design to create an uprated suspension piece that not only withstands the higher demands of performance driving while smoothing out the S197's ride by reducing wheel hop and windup. . This control arm is designed as a direct OE replacement for the factory upper control arms of 2005 to 2009 Mustangs.
The large, tubular design is far stronger than the stamped steel of the factory upper arm, allowing the Steeda version to handle more torque without deflecting, warping or breaking. Each arm comes with an integrated polyurethane bushing to for extra strength and greater lifespan than the factory's rubber bushings. The unique stepped spacer design allows the arm to accept the stock bolt more snugly than other bushing systems to avoid noise and instability issues that are seen when trying to mate the factory 14mm bolt to the 16mm mounts of aftermarket control arms.$80 shipped
if you are interested text me 281-881-8352 israel
