2009 Mustang GT Door Panels Leather Peeling
It's actually vinyl. At any rate, I've been told the method is to rub as much of the foam off the door panel as you can with your thumb, then use contact cement. I tried this method and it was fine until the first hot day, then the inserts fell off again.
Silicone works very well but doesn't hold the insert in place very well while it's curing, so it has a tendency to slip and not look as good when it's done.
