255lph pump
  • Thread starter Thread starter luckythirteen13
  • Start date Start date Sep 23, 2005
L
luckythirteen13
648
Anaheim, CA
Sep 23, 2005
  • Sep 23, 2005
will a 255lph in tank pump support a sc motor making 425rwhp+ with 42# injectors? i have the 255 now and have the t-rex but was wondering if i really need it. how exactly does having two pumps on the same fuel line work exactly?
D
dwhiskie
183
  • Sep 23, 2005
Thats all I have, no T-rex and no problems
vristang
4,933
101
124
Seattle
Sep 24, 2005
  • Sep 24, 2005
Here are some recommendations that I worked out according to formulas I found in Four Stroke Performance Tuning by A. Graham Bell. Running at 80% of plump capacity helps ensure a long life from the pump.
_____________________80% of Max______80% of Max
Ford EFI Options_______N/A Limit________Boost Limit
110 lph________________240 hp__________200 hp
155 lph________________340 hp__________280 hp
190 lph________________420 hp__________340 hp
255 lph________________560 hp__________460 hp
I recommend considering future plans when deciding on a fuel pump.
You should be ok. With more power though you will most likely need the secondary pump.
jason
L
luckythirteen13
648
Anaheim, CA
Sep 24, 2005
  • Sep 24, 2005
looks like im probably going to be needing the second pump. are those numbers crank or rear wheel hp? i know i wont hit 460rwhp but ill pass 460 at the crank for sure
Dbeck002
710
South florida
Sep 24, 2005
  • Sep 24, 2005
I think your main problem is the injectors. 24 lbs are too small for 400 RWHP. pump should supply enough fuel for a car running 10s, injectors are just small.
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Sep 24, 2005
  • Sep 24, 2005
He said 42#.
a 255 pump should be fine, but a T-Rex would not be overkill either. From what I hear, it draws when required.
vristang
4,933
101
124
Seattle
Sep 24, 2005
  • Sep 24, 2005
Those are for crank hp, I believe. I will double check when I get home tonight.
L
luckythirteen13
648
Anaheim, CA
Sep 24, 2005
  • Sep 24, 2005
dan is refering to they 24# injectors i have now. they handled with an fmu up to 350rwhp but they were going lean. that was also below 4500rpm. all the dyno runs were cut at 4500rpm cause my fuel system just couldnt hack it
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
