289/302 heads.
  • Thread starter Thread starter Dave Moors
  • Start date Start date Mar 19, 2007
D
Dave Moors
  • Mar 19, 2007
HI all,
I've been offered a pair of 302 heads in better condition than my existing (i think) 289 heads that will allow me to get back on the road quite a bit quicker but can anyone tell me where I can find info on the differences between the 2 head types and if I need to do anything to the block?
Thanks
D
danny clemens
728
  • Mar 19, 2007
Depending on the year 302 heads it could lower your compression quite a bit and hurt performance.
T
toolwench
21
Los Angeles area
Mar 19, 2007
  • Mar 19, 2007
Yeah, it depends what the heads are out of/what year they are. If you just wanna get the car running, that's a whole other ball of wax, too.
I mean, after toasting a motor, I cleaned the rust off an old shortblock and went to the junkyard to get heads out of anything 302 just to get back on the road. I ended up with heads from a 70-something T-bird and that motor ended up lasting me five years. I saw about 120 on the freeway one night and it didn't sound like it was going to explode. When I swapped it out for a crate motor, the only thing wrong was a leaking front main. It has now been cannibalized into two other motors.
streetdemon70
57
  • Mar 19, 2007
so if i put 289 heads on my 302 will it bump compression?
D
D.Hearne
11,730
south louisiana
Mar 19, 2007
  • Mar 19, 2007
Depends on what 289 heads you're talking about. They're not all the same. The early ones had a small 54 cc chamber. The later ones grew to 58 or 60 I think. The so called 68 Stang "J" code 302 heads were simply recast early 289 heads (C6OE) and had that same small 54 cc chamber, hence the 10.5 to 1 comp ratio. 302 heads had 54, 58, 60, 64 and 79 cc chambers, depending on the head casting.
M
mustangguy289
42
  • Mar 19, 2007
Ive got some hopped up 65 yr model casting 289 heads. larger valves dobl springs port etc. Pm me if interested also have the cam and lifters that match springs.
streetdemon70
57
  • Mar 20, 2007
pm sent
D
Dave Moors
  • Mar 20, 2007
I spoke to the seller and they are allegedly from a 91-94 302 motor. The existing engine i am told came out of a 67 cougar. Can handle the loss of some performance esp if it helps me get on the road sooner. Plus our gas prices are going up again as our government goes all "green".
Thanks for assistance.
T
toolwench
21
Los Angeles area
Mar 20, 2007
  • Mar 20, 2007
I could be wrong, because I honestly don't remember for sure, but when I was junkyard-hopping for a set of heads I could use, the later ones had some sort of smog inlet or something. It wasn't that they wouldn't mate to the block, but that there was essentially a hole in the head that needed to be addressed. I chose the oldest set in the yard so that I wouldn't have to deal with any oddities like that.
Once again, I could totally be wrong because I don't remember for sure, but it'd suck to get all the way into it and excited about getting the thing together only to find out you've got another thing to deal with. I hope I'm either wrong or that it's not a big deal.
Soaring1
Banned
Jan 3, 2003
144
Texas
Mar 20, 2007
#10
  • Mar 20, 2007
  • #10
Heads
What you really want to find are some gt40 heads.
D
D.Hearne
11,730
south louisiana
Mar 20, 2007
#11
  • Mar 20, 2007
  • #11
If you 67 heads are the following casting numbers : C7OE-B, C7ZE-A, C8OE-D, L, OR M, These have 63 cc chambers, E7's are 64cc. Mill them up to .040 and you'll gain some compression.
streetdemon70
57
#12
  • Mar 21, 2007
  • #12
so if i put some 65model 289 heads on my stock 70 short block 302 what compression ratio would i be looking at? what was stock for a 70 302?
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Mar 21, 2007
#13
  • Mar 21, 2007
  • #13
IMHO if you really want to wake up a 289/302 with a stock head than you should be looking for a set of 69-74 351W heads. If a port is too small it may yield velocity from low end torque but it has no performance when it is time to open the throttle, the engine just struggles too much to breath. The 351W's are a great compromise and if you bother with a good port and bowl job it's an outstanding stock head.
D
D.Hearne
11,730
south louisiana
Mar 22, 2007
#14
  • Mar 22, 2007
  • #14
Depends on what pistons you have now. This combo is essentially what the 68 4 bbl 302 was (J code) 10.5 to 1.
M
mustangguy289
42
#15
  • Mar 22, 2007
  • #15
Posted this same question about the 65 head on a 70 302 on corral.net here was one the only answer so far.
If it is a true 1970 piston, the one with the small dish (not a flat top 4 eyebrow), then the 54cc 289 head is going to bring it up to around 9.5:1. The 1970 set-up would have been using the 58cc head and had around 9:1. So for this geometry, the 4 cc smaller combustion chamber is going to increase Cr by ~ 1/2 a point. this is for the stock configuration and a gasket thickness around .040, deck clearance .012.
streetdemon70
57
#16
  • Mar 23, 2007
  • #16
thanks man. pm sent back
jeffnoel
1,638
Clovis, CA
Mar 23, 2007
#17
  • Mar 23, 2007
  • #17
Check out this chart for compression ratios when swapping heads.
http://www.mustangii.net/headswapcompression.asp
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
T
Engine 1970 302 boss block
  • TOM B
  • Jan 4, 2025
Classic Mustang Specific Tech Jan 14, 2025
lqbbe
L
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech 28 minutes ago
Blackhawkxx
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
