289 header spark plug problem
  • Thread starter Thread starter TeamEntity
  • Start date Start date May 15, 2010
T
TeamEntity
130
  • May 15, 2010
installed my new set of flowtech headers today and they fit really good. But on the drivers side only the o.e spark plugs do not make it past the first two cylinders neither do the supplied bolts. this is because the header tubes make a sharp turn and do not allow clearance of both of these parts. so now what? no shorty plugs seem to be made same with bolts
rbohm
6,698
550
204
tucson,az
May 15, 2010
  • May 15, 2010
the bolt issue isnt really a problem, you can get allen head bolts for the header from a number of sources. as for the plugs, try accel and see if they have a shorty plug that fits the ford head.
check here;
http://www.thefind.com/cars/info-shorty-header-plug
T
TeamEntity
130
  • May 15, 2010
yeah i also had a set of allen head round bolts and there still too long in order to be able to get them straight to get em started. Also i don't see an 18mm thread spark plug from accell to fit these.
rbohm
6,698
550
204
tucson,az
May 15, 2010
  • May 15, 2010
you might try leaving the header loose when trying to start the header bolts. or order a custom set of bolts from arp.
T
TeamEntity
130
  • May 15, 2010
what about the plugs? same damn thing?
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
May 15, 2010
  • May 15, 2010
I recommend you call their tech support line, it sounds like you got a defective set.
T
TeamEntity
130
  • May 15, 2010
Oh great. Another fine product owned by "holley"
Realmongo
2,466
86
99
Western Mass
May 16, 2010
  • May 16, 2010
They own Hooker too and I have never had a problem with those!
woodsnake
1,352
15
69
Hicksville, NY
May 16, 2010
  • May 16, 2010
I've had several pairs of headers that required bolt installation in order. They are always a tight fit. Start on both ends to hold the header up. Then, try and get the inside ones started. You may only be able to get a partial turn on each bolt, before they start to fight you again. This is just a test of your commitment, don't give up so easy....
G
grainboy
140
Goodyear, AZ
May 17, 2010
#10
  • May 17, 2010
  • #10
I had the same problem with headers on my windsor Jr heads. You have to leave the headers loose, possibly with studs at both ends, and shorty accells do exist, and are necessary, and the plugs get torqued before the header goes on tight. A very thin plug socket and wrench does the trick. I taped my wires with msd high heat tape, and extended the life of the boots a little.
those header gaskets with the loop hangers on the ends are great.
T
TeamEntity
130
#11
  • May 17, 2010
  • #11
geez i would hope if i spent over 400 to a grand that none of these problems would exist. I guess you get what you pay for. btw, i got them installed yesterday exept one bolt. there is not room in there to finish tightening this one bolt before the wrench strips right off of it.
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
