289 HELP
  • Thread starter Thread starter barney67
  • Start date Start date Aug 10, 2006
barney67
  • Aug 10, 2006
HELLO !
I JUST BOUGHT A 1967 COUPE WITH A 289 2BRL AND I CANT GET IT STARTED!!! THE CAR HAS BEEN SITTING FOR 16 YEARS IT TURNS OVER AND I GOT SPARK AT THE PLUGS. I TRIED STARTING FLUID IN THE CARB AND NOTHING I ALSO TRIED GAS IN THE CARB AND STILL NOTHING !!!!!!!!!!!
WHAT ELSE SHOULD I TRY ? COULD IT BE STUCK VALVES ?
krash kendall
1,258
Aldergrove, B.C. Canada
Aug 10, 2006
  • Aug 10, 2006
Stop yelling please.
geostang351
946
Danb., CT
Aug 10, 2006
  • Aug 10, 2006
R
Rapid
297
Columbia, SC
Aug 10, 2006
  • Aug 10, 2006
Check for compression.
Make sure the rotor turns when the engine does.
Make sure that #1 is at TDC when the rotor is pointing to the #1 plug wire.
Make sure the plug wires are in the proper firing order.
Buy a Manual with trouble shooting section. It will help you through the process.
GoinBroke
109
Joliet, Il
Aug 11, 2006
  • Aug 11, 2006
I would recommend pulling the valve covers if it has been sitting that long to check rocker/lifter movement. Mine had been sitting for a similar amount of time and when I rotated by hand to remove the tranny it did have 2 valves seized in the head. I was planning a rebuild anyway but if you are going to try to have a dependable ride I would pull the intake and heads to see if any repairs are needed or at least do a compression check.
67CoupeDriva
165
South Carolina
Aug 11, 2006
  • Aug 11, 2006
If you have spark then check for timing. Also replace the fuel filter, drain the tank and add fresh fuel if you haven't already. The carb may be shot, dried seals and gummed jets for example...you could try a rebuild kit or just get a new or rebuilt one (probably your best bet).
Do go over the engine really well before starting, pull the valve coveres as suggested, you may even pull the oil pan to remove the sludge that is almost certainly there and verify that there's nothign visibly wrong with the bottom end. Sometimes people "forget" to tell you that the reason it's been sitting for so long is because it threw a rod or something.
D
danny clemens
728
  • Aug 11, 2006
If you put gas in the carb and it didn't even hit I would suspect either flooding or an electrical problem. Even if one of these are a problem there still could be others.
barney67
  • Aug 13, 2006
thanks for the help it was the point gap.
L
limey66
408
Northampton, England
Aug 14, 2006
  • Aug 14, 2006
Fuel pump diaphragm - if it's been sat for 16 years it will have gone hard and broken the moment you turned it over (I'd guess anyway). Get some fresh gas, and fill the carb up through the vent stubs. If all else is OK she should start and splutter for a while until the gas runs out...
My two pence...
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
