  • SN95 4.6L Mustang Tech
2V-->4V conversion???
  • Thread starter Thread starter smokin'Red35th
  • Start date Start date Jul 6, 2004
smokin'Red35th
493
Las Vegas, NV
Jul 6, 2004
  • Jul 6, 2004
Someone clear this up for me please....
Is the main block the same for a 2v and a 4v? If so, why couldnt one convert their 2v SOHC to a 4v DOHC? I hope this question doesnt sound dumb, but i'm trying to understand this.
svtguy
1,094
Calgary, Alberta
Jul 6, 2004
  • Jul 6, 2004
No the block isn't the same, but thats just one of many things. While both motors are 4.6L's that's where the similarities end, as they share no parts in common. A complete 4v crate motor is the only route to go & unless you own your own shop & do your on work, a 4v swap is neither cheap nor easy.
That being said if you own a 99+ GT & want 4v power, sell your current car & buy either a new or a used Cobra. If you own a older GT that needs a new power plant then a 4v Crate motor could be fun.
millhouse
1,985
Simpsonville, SC
Jul 6, 2004
  • Jul 6, 2004
Although the block's are not quite the same, they are similar enough to be able to slap on the 4v heads and all of the supporting hardware on a stock 2v shortblock. I believe the only thing different that you would need would be the alternator and perhaps the electronics.
With that being said, the 2v's dont have a forged crank for those high rev's that the 4v's have stock.
It took my brother and I around 4 months of weekend and occasional weekday work to convert a 99v6 into cobra via a 96 driveline. Keep in mind we had air tools, and almost no support for a older engine into a newer car swap (different fuel systems, computers, harnesses, connectors etc.) It took more time figuring things out most of the time than it did to actually do the work.
smokin'Red35th
493
Las Vegas, NV
Jul 6, 2004
  • Jul 6, 2004
Id probably end up dropping a 4V crate motor in there anyway, i was just curious. And no, im not selling my car
Aaron 4.6
2,695
Georgia
Jul 6, 2004
  • Jul 6, 2004
Engine swaps aren't ever cheap or easy. Its an ENGINE SWAP. That having been said, a 4V swap is about as cheap and easy as it gets. You can get complete engines for less than 3k, and you aren't exactly breaking new ground. Hell, there is a website dedicate to EXACTLY this swap. www.cobrapoweredgt.com
The motors have a LOT more in common than the displacement, although there are significant differences. However, its completely 'do-able' to slap 4V heads on a 2V block. Its just smarter to swap the whole engine.
walker887
451
Apollo Beach FL
Jul 6, 2004
  • Jul 6, 2004
guys to clear it all up , yes the 2V can be converted , we have done it now to all years of blocks.The 2V W block needs some grinding up in the valley area to clear the intake.
I will someday soon update Cobra Powered when time is avail to list all of this
Don
nickthegenius
1,631
Elwood, IN
Jul 6, 2004
  • Jul 6, 2004
svtguy
1,094
Calgary, Alberta
Jul 7, 2004
  • Jul 7, 2004
I think all of you guys are all missing the boat on my post. ie: A 4v engine here will run you between $4 - 5,000 CND & Unless you OWN a shop & do all your own work your looking at another $2,000 to do the swap or more. If I own a 2001 GT with low miles, I can sell if for about $22,000. A similar low mileage 2001 Cobra can be had for about $29,000.00
$22,000 + 5,000 + 2,000 = $29,000.00
Hmmm...4 valve swapped GT or Cobra cost about the same. Except ones worth more & will always be worth more & offers may advantages & improvements over the other.
So unless you run across a free 4 valve motor or one that's extremely cheap, it makes very little sense for most people to do a swap. Bastardizing a 2V GT motor into a 4v makes even less sense.
M
michigan98gt
  • Jul 7, 2004
http://www.karkraft.com/mach1_engine1.jpg
This sells for 3200. Only 300 miles on it. SOunds dumb, but what would estimated labor be to drop this in my 98Gt 5-speed??
Otherwise, what all is needed to get 300rwhp N/A on my 2v? Thanks!!
hognutz
1,940
albany, oregon
Jul 7, 2004
#10
  • Jul 7, 2004
  • #10
I don't know why you would do a swap when you could just do 2v heads and cams. I mean stock cobra don't throw down over 300rwhp. I mean if your goals are only 280-300rwhp why not just do heads and cams on the 2v. it will cost 3k but there is no "swaping" just replacing.
now if you goal is to mod the hell out of the 4v then by all means swap it in as there is more potiential there.
Aaron 4.6
2,695
Georgia
Jul 7, 2004
#11
  • Jul 7, 2004
  • #11
svtguy-
I recognize your point completely, and it is a valid one. In fact, I did exactly what you suggested. I went from a 99 GT to a 98 Cobra because it was, in my mind, the smart way to go. I guess I just wanted to emphasize that the 4V swap isn't some impossibly hard swap that costs a bajillion dollars. It might not be the easiest way to go, but a lot of people have done it.
Patrick-GT
40
Sacramento
Jul 8, 2004
#12
  • Jul 8, 2004
  • #12
There is a huge difference in insurance cost though, keep that in mind.
smokin'Red35th
493
Las Vegas, NV
Jul 8, 2004
#13
  • Jul 8, 2004
  • #13
well, My car has more value to me than any other "standard" GT. If I was offered a cobra for my car as an even trade, i still wouldnt get rid of it. Simply because very few people have my car. there are 1550 just like it (same color) throughout the united states and Japan. So, that being said, my car holds more value to me and makes it worth the swap.
(If i had any other 99-04 gt, i would just say screw it and trade it for an 03 cobra)
smokin'Red35th
493
Las Vegas, NV
Jul 8, 2004
#14
  • Jul 8, 2004
  • #14
hognutz said:
.......now if you goal is to mod the hell out of the 4v then by all means swap it in as there is more potiential there.
That is my whole reasoning for doing the swap. I want the added potential for when i get my Kenne bell.
Aaron 4.6
2,695
Georgia
Jul 8, 2004
#15
  • Jul 8, 2004
  • #15
Not necessarily. Liability is basically the same. Both cars are considered V8 sports cars. And if the cars are not too far apart in appraised value, the collision shouldn't be much different. Going from a 97 GT to a 2003 Cobra would be a big jump, but a 00 GT to a 99 Cobra should be pretty close. My insurance actually went down a hair when I got the Cobra.
This may vary with insurance carrier.
svtguy
1,094
Calgary, Alberta
Jul 8, 2004
#16
  • Jul 8, 2004
  • #16
Well some of us get attached to certain car that's understandable & a 4v sleeper GT would be cool. But a logical question you have to ask yourself is, do I ever intended to sell the car? I know you love your current car now but few years down the road when the 05+ GT's start catching your eye, will your opinion change? Another one is do I have to trade in my current toy to buy another?
BTW: 03 Cobra crate motor all the way if you want to s/c.
BTW: Here are the number counts for convertible 03 Cobra's, if rarity of color is what you desire you can see that all colors but black will few & far between.
Convertible: Black 1,679; White 308; Yellow 319; D.S.Grey 446; M.Grey 154; T.Red 582; Red.F 610; Blue 355; S.Silver; 81; Silver M. 548;
http://www.svt.ford.com/svtArchiveC...a03&vehicle_two=nothing&vehicle_three=nothing
J
jbritt1234
156
Knoxville, TN
Jul 8, 2004
#17
  • Jul 8, 2004
  • #17
I priced the increase when I was consicering a 03 Cobra vert from my 02 GT Vert. It was only $17 more a month. 30 years old and State Farm Ins.
hognutz
1,940
albany, oregon
Jul 8, 2004
#18
  • Jul 8, 2004
  • #18
if you are getting a kenne bell I would just do a forged shortblock and the kb. I mean last time a checked 500hp+ was about all you can handle in a street car without lots of suspention mods anyway. with 14psi and everything tuned right you should be over 500hp.
I mean just adding a kenne bell to you 2v now with new maf, air intake etc would have you in a pretty fast ride.
If you plan on supercharging I see no reason to go to 4v unless you just have to be a 4v. staying n/a there is a advantage for sure.
N
Newedge3
Pennsylvania
Nov 10, 2020
#19
  • Nov 10, 2020
  • #19
I literally did this hole swap with basic hand tools a junkyard motor and elbo grees and in my front yard at that. Total hours invested to swap and here it start. 4-6 hours. Most time consuming part was extending the COP plugs
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
