  • SN95 4.6L Mustang Tech
2V vs. 4V
  • Thread starter Thread starter 85MustGT
  • Start date Start date Aug 31, 2004
85MustGT
95
Occupied San Diego
Aug 31, 2004
  • Aug 31, 2004
First of all I know the 4 cam engine makes more power but why?
Seems all the extra valves and cams would slow the engine down, I trying to make sense of this?
crew_dawg16
445
DeKalb, IL
Aug 31, 2004
  • Aug 31, 2004
If you have a cylinder head that has 2 valves, you are limited to how big the diameter of those valve can be by the width of the combustion chamber. If you put 4 valves in a head, you can now have 2 smaller intake and 2 smaller exhaust valves that add up to a bigger overall area. This allows you to flow much more air at higher rpms.
Dr. Wu 2000
554
Eastern, Pa.
Aug 31, 2004
  • Aug 31, 2004
Both the 2v and 4v modulars love to rev, but the 4v really shines at higher rpm's, where the 2v's run out of breath, so to speak.
H
hexum311
98
FL
Aug 31, 2004
  • Aug 31, 2004
More valves = more flow = more power.
article quote:
"Usually, double overhead cams are used on engines with four or more valves per cylinder. A single camshaft simply cannot fit enough cam lobes to actuate(operate) all of those valves"
http://www.streetracersonline.com/articles/camshafts/2.php
R
Rocketman
730
SoCal
Sep 1, 2004
  • Sep 1, 2004
Short answer, because the 4v flows more air, which equals more HP.
Long answer: This is right out of the book.
The 4v engine does not require as much valve lift to achieve high flow rates, because the valve curtain area of the valve is the limiting factor to flow. The curtain area of a 4v design is much larger at lower vale lifts than a similar 2v design. A single intake valve would require a valve lift of .821 inches to match the valve curtain area of the 2 smaller intake valves in a 4v design with only .500 inches of lift.
Valve curtain area comparison:
4 valve head with two 37MM diameter intake valves with .500 inch of lift equals a valve curtain area of 4.57 square inches.
2 valve head with one 45MM diameter intake valve with .821 inch of lift equals a valve curtain area of 4.57 square inches.
This is the advantage a 4v head has over a 2v. To achieve over .800 inches of lift on a 2v design requires some very exotic valvetrain components, where achieving a similar flow potential with a 4v head can be achieved using mostly production pieces.
C
CatmanJJ
Captain Tangnet
20+ Year Stangneter
Feb 5, 2002
4,379
Maryland
Sep 1, 2004
  • Sep 1, 2004
Like these guys said. Also if you ever have gone from a 2v SOHC GT to a DOHC 4v you'll immediatly notice a huge difference up top. Right when the 2v starts to run outta air and start weezing is where the 4v really starts to shine I think, up top around 6000 rpms.
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
4v cobra exhaust compatibility
  • Kid wita 5oh
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 30, 2026
squeak93
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
