3.73s
  • Thread starter Thread starter Blake22
  • Start date Start date Apr 1, 2010
1 of 2 Next Last
Blake22
65
  • Apr 1, 2010
how much will 3.73s hurt my gas milage
Mustang_Fan
80
  • Apr 1, 2010
Not as bad as your right foot
xgto
26
  • Apr 1, 2010
No effect at all that I have found. just wears out your rear tires faster !!
YELLOW42RCODE
346
San Diego, Ca.
Apr 1, 2010
  • Apr 1, 2010
They won't as long as you stay out of it. Normal driving is fine.
scupking
1,186
Enfield, CT
Apr 1, 2010
  • Apr 1, 2010
Heck I have 4.10s and 360 crank up. I still get 18 mpg mixed around town and highway. If I was all highway I would be probably around 23-25mpg at 70mph.
cusp
61
Santa Barbara
Apr 1, 2010
  • Apr 1, 2010
From what? 3.31? That mod reduced my Highway MPG by about 8 to 10 Percent. In town its up to me. If choose gears which result in the lowest RPM, then I can get about 3 percent better mpg. But if I get aggressive, its 13% worse. The latter is hard to avoid. Hopping on the highway is more fun.
StuckInNY
32
NY
Apr 1, 2010
  • Apr 1, 2010
But that is on a 5-speed with 3.73's. A 6-speed with 3.73's is like a 4.11 for your car, correct?
Big Large
47
mechanicsville, va
Apr 4, 2010
  • Apr 4, 2010
5spd or six speed doesnt matter. what matters is the final drive ratio of the tranny which would be close to each other. i went from 355s to 410s and my rpms went up only 300 at 70mps in overdrive. or 5th gear which ever you prefer to call it. biggest thing to think about is if you are worried about gas mileage then you probably shouldnt be modifying the car anyways
H
hookit2
grand island,fl
Apr 4, 2010
  • Apr 4, 2010
according to the research i done on trans ,5 or 6 speed the gear ratio is realitive to application, and only 1 gear differed by application, these are not exact but, 331 gear cars came with 338 first gear 5 speed where factory 355 and 500 came with 295 first gears trans both five and six in 05-10 applications, however there was some choices on final drive numbers:Track:
cusp
61
Santa Barbara
Apr 4, 2010
#10
  • Apr 4, 2010
  • #10
If you talking about the 2011 GT with its 6 speed. Were it me, I think I would opt for the 3.55s. Because of the lower 1st and Higher 6th, 1st will be like the 5 speed with 3.73s. And 6th would be like the 5 speed with 3.31s. Seems about right to me from how I drive my car. Spirited but not racing.
I
IWantMyNewGT
32
#11
  • Apr 5, 2010
  • #11
Sounds like a good combo. My '10 GT with 3.73s is quick off the line, but feels likes it needs a 6th gear overdrive when I settle in on the freeway at 70 or so. In fact I sometimes reach down to shift for a 6th gear that isn't there...
Mustanglvr2006
340
Somewhere
Apr 5, 2010
#12
  • Apr 5, 2010
  • #12
Hi Big Large, what year is your mustang? I have an 06 GT 5sp auto, and I have been thinking of going with the 410s, I have done some research as to what kind of RPM changes I will be looking at, off the top of my head I think the consensus has been around a 400-700 RPM difference at 70mph in 5th from my stock 331 gears, I hoping for the lower 400, but I'm sure it will be closer to 600 or 700, what RPMs are you turning at 70mph in 5th?
Big Large
47
mechanicsville, va
Apr 5, 2010
#13
  • Apr 5, 2010
  • #13
mustanglvr my stang is an 05 with the the manual. im turning 2550rpm at 70 in 5th with the 410s and 2750rpm at 75mph. im loving my 410s but my car is a fun car for the most part. only put 2300 miles on it since i bought it in november. 1st goes by quick, 2nd feels almost like stock 1st gear and 3rd and 4th pull like a beast. my car is stock other than mufflers and the gears. im ordering my cai and tuner from americanmuscle tomorrow so im pretty pumped about that
ViperNuge
197
Maui
Apr 6, 2010
#14
  • Apr 6, 2010
  • #14
Mustanglvr2006 said:
......, what year is your mustang? I have an 06 GT 5sp auto, and I have been thinking of going with the 410s,?
We have the same car dude. Get a brenspeed/cai tune combo first or when you order your 4.10 gears. The car is so much better with 4.10s. My car ran a 13.9 stock. With gears, tune/cai it ran a 13.4. Huge difference in how it drives and responds to the gas pedal. Dont be afraid to mod your stang!!!
patrick
G
Gregor111
95
Spokane, WA
Apr 6, 2010
#15
  • Apr 6, 2010
  • #15
I agree 100%. 6th gear on the new car is only about 4% taller than 5th last year. In one of the magazine comparison tests, they showed each car's rpm at 60mph. The new stang was at 1,950 with the 3.73 whereas the competition was about 500 rpm lower.
Given that the new car has over 100 more hp, almost 100 more lb/ft of torque and six closely spaced gears, it should still really rip from 0-100. Many people say the drop in rpm at freeway speed isn't great enough to justify the decrease in performance. Well if the change isn't that great at freeway cruising, how can it be that much better for acceleration?
Greg
Mustanglvr2006
340
Somewhere
Apr 6, 2010
#16
  • Apr 6, 2010
  • #16
Hey thanks for those #'s Big Large, good to know...looks like ViperNuge has exacty the #'s I'm looking for, being that his car is auto with 410s.
patrick
Hey Viper, what kind of RPMs are you turning at 60mph and at 70mph in 5th? I have been very curious about this since I started thinking about doing the 410s rather than the 373s. I am not worried about the gas mileage, just more concerned about the revs at higher speeds.
I have been looking and looking to get the exact #'s on this for a while now, I'd appreciate if you could tell me. Thanks in advance man.
G
gerhardtracing
24
#17
  • Apr 6, 2010
  • #17
I had 4:56's in my 2008 gt I just sold, I loved them! even making that big of a jump from 3:55's I got better city mpg, and lost about 3mpg on the highway. but it was worth it. I dropped my 1/4 times by about .5 seconds
sjpony
100
#18
  • Apr 6, 2010
  • #18
BigLarge,
Wow, that is high RPM, but then you ahve 410s. My 07 with 373 is @2500 at 80. Shifting sounds the same. 3rd and 4th pull like mad. 5th seems a little high strung. I wish mine had a 6 speed.
L
liberty911
SE Florida
Apr 15, 2010
#19
  • Apr 15, 2010
  • #19
I lost 2 mpg overall going from 3.55 to 3.73 with a AT. I drive 50-50 hwy/street. RPMS increased approximately 250 at highway crusing. Nice gears and I'd do it again.
JonStolo
20
#20
  • Apr 17, 2010
  • #20
My general rule of thumb over the years for all my mustangs has been to go down 2 FRPP gear ratios. So basically:
3.31 to 3.73
3.55 to 4.10
1 of 2 Next Last
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
WTB/Trade wtb low milage 87-93 mustang gt/cobra hatchback
  • terminate
  • Dec 20, 2025
Fox Body Mustangs For Sale (1979-93) Dec 20, 2025
terminate
T
Drivetrain Can’t identify correct speedometer gear
  • townethug
  • Jul 12, 2025
Fox 5.0 Mustang Tech Jul 21, 2025
FastDriver
D
Catless hpipe
  • Dauryd12
  • Apr 18, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 20, 2026
squeak93
1965 mustang 351 850 hp+ primary tubes 1 7/8 or larger and a 3 inch or larger collectors?
  • 427nostang
  • Jun 4, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 7, 2026
DadLife0724
