3.8 to 5.0
  • Thread starter Thread starter bigponi4123
  • Start date Start date Nov 15, 2011
bigponi4123
ct
Nov 15, 2011
  • Nov 15, 2011
i have a 1996 3.8 and want to do a 5.0 swap have motor and rear end what else will i need any help would be great
SlammedGT
581
9
29
Peotone, IL.
Nov 16, 2011
  • Nov 16, 2011
This forum
BlackVert
5,589
9
98
Bethesda, MD
Nov 16, 2011
  • Nov 16, 2011
Sorscode: Performance & Swap Specialists
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Nov 16, 2011
  • Nov 16, 2011
You'll need a donor car for parts, Ford changed around a lot of the wiring inside the cars in 1996, so you'll have to take more than the motor and transmission. I have never owned a 1996 3.8 Stang, so I cannot tell you what's different and exactly what to swap. If you can get a 1994 or 1995 3.8, the swap is relatively easy. Check out the link in my signature for my 1994 3.8 to Cobra 5.0 swap.
screamin5oh
170
centerville oh
Nov 17, 2011
  • Nov 17, 2011
you will need a k-member from a 94/95 mustang, and engine harness from 94/95 gt, i also think you will need the body harness from a 94/95 gt. then a complete drive line from a 94/95 gt, if your going carb then all you will need is a k memeber from a 94/95
BlackVert
5,589
9
98
Bethesda, MD
Nov 17, 2011
  • Nov 17, 2011
i thought the motor mounts for the V6 were the same as they are for the 5.0 ... no?
or is that only the 94/95 V6s?
bigponi, are you going carb?
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Nov 17, 2011
  • Nov 17, 2011
As I understand it, the 94-98 V6 engines are the same and use the same mounting locations as the 86-95 5.0. So his k-member should be just fine. What I'm not sure of is the dash and body wiring. I know Ford made some changes to the wiring to save some $$$$, but I don't know if the changes were just to the 4.6 chassis or to the 3.8 as well.
screamin5oh
170
centerville oh
Nov 17, 2011
  • Nov 17, 2011
no your wrong, just 94/95 had the same k member. once they went with the 4.6 in 96 the motor mounts also changed for the 3.8
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Nov 17, 2011
  • Nov 17, 2011
I know the engine block is the same, so I presumed that Ford would keep the same k-member and motor mounts. A bit of research online tells me that Ford did switch the k-member in 96, and created new motor mounts for the existing 3.8 V6 to fit the new k-member. *shrug* I presumed poorly, then.
M
Mustang95GTS
96
#10
  • Nov 17, 2011
  • #10
if you need the main harness that plugs into the CPU I have one if you are interested in buying it.
W
Strange connector near fuse box
  • W4rl0ck
  • Sep 23, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 28, 2026
gkomo
C
Progress Thread Whats needed on a 3.8 for a super charger to work reliably?
  • Cryfire
  • Nov 4, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
gkomo
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Cooling fan identity
  • SteveG94GT
  • Apr 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
SteveG94GT
