30/lb Injectors, Overkill or OK?
UpRise_5.0
664
Canada
Would 30/lbrs be ok or to much?
Heres the combo
Gt40 Iron Heads
E-Cam with 1.7 RR - 526/526 lift
TF Street Heat Intake
73mm Mass Air
65mm Throttle Body
AFPR
255/lph Fuel Pump
Complete Exhuast
Now, I know 24/lbers would be the best, But I plan on eventually running most likely Nitrous. Or if I could afford it instead an A-Trim/Sc Trim or Novi 1000 with around 6-8 psi with a FMU.
From what I understand, if you are planning future mods, you could go even higher, up to 38lb without problems. The 30's would be fine, with no cold startup problems. Rick Anderson or Anderson Motosport advises that nothing short of 36lb injectors be used, because it precludes the changing of injectors with every mod you make, and is still great for the street.
