302>>>>347 short block
lookout4me
Banned
Apr 3, 2005
35
ok i read that some where in these post that you can take a 302 block and swap a 347 block into the bottom half with out changein a single thing.
how would this be done. and if so where can i find one that is cheap so i can do the swap.
You reuse your block with and overvore. The crankshaft has longer throws on it. The rods and pistons are shorter to fit into the same space. This increases the stroke and therefore displacement of the engine. Kits can be bought to do this or you could opt for one already built( a shortblock).
2bav8 said:
I got me one of dem there stroker thingies :)
Run real well too.
Damn, 2bav8, you're not a coon-ass are you? :D Sure sound like one there. Got me one dem 331 strokers dere too, ya. :D ----------------------------And mustangdave, the rods in a 331-347 are longer, not shorter. I'f they were shorter, the pistons would hit the crank counterweights at BDC.
im sellin my 347
ive got a 347 im selliin if your interested. below is a lis of internals. ive got a 9 in rear and a 4 spd toploader close ratio if your interested. PM me if you want anything.
-289 block bored to 347 (5 bolt)
-stroker kit
-Eagle H-Beam Rods
-Ross Pistons 11:1 comp.
-Roush cometition heads
-Competition Cams Valve Train, with solid cams and roller rocker arms
-New Intake
-Canton 7qt. oil pan + windage tray
-March Pulleys
-1 wire powermaster
-Barry Grant Demon Carb
-MSD ingnition and coil
-MSD distributor
-New water pump
-New valve covers
4000 for engine and 500 each for 9in and 4 spd.
thanks again
