302 BLOCK
  • Thread starter Thread starter RAYMOND259
  • Start date Start date Feb 2, 2007
R
RAYMOND259
56
  • Feb 2, 2007
Can I use a 87 truck roller block in my Stang?Thanks
C
C0V3R
524
Australia
Feb 2, 2007
  • Feb 2, 2007
Probably, is it a 351 or 302? more details about the stang? Year?
Chietala
111
Sacramento
Feb 3, 2007
  • Feb 3, 2007
Id be sure it's a roller block because they didnt go roller until 93 (in trucks).
What did it come out of??
Also if its not roller and you want the roller cam to work your looking at a $500 set of lifters. If the block is bare check to see if the lifter galley has been machined for lifter guides.
R
RAYMOND259
56
  • Feb 3, 2007
It a Roller block it have two hole for the spyer
Chietala
111
Sacramento
Feb 3, 2007
  • Feb 3, 2007
Non rollers can have the holes as well.
You don't know what it came out of?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 4, 2007
  • Feb 4, 2007
Keep in mind that non roller camshafts use an iron distributor gear. Roller cams use a steel gear. Anytime you swap cam types, you need to swap the distributor gear to match.
R
RAYMOND259
56
  • Feb 4, 2007
nope it was a bare block.lifter gallery is machine
Chietala
111
Sacramento
Feb 5, 2007
  • Feb 5, 2007
Well then I'd say yeah you can use it. I just used a 302 roller from a 92 lincoln.
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
