302 Efi Hood Clearance
  • Thread starter Thread starter robert fugate
  • Start date Start date Jan 27, 2014
robert fugate
103
25
39
valdosta ga
Jan 27, 2014
  • Jan 27, 2014
My dads sticking my old 302 into 1969.. efi with the explorer intake.. Problem is with that intake and the valve covers i had to run a 1" spacer to clear them.. Will he have a clearance issue? Thanks
horse sence
8,563
233
Wile Coyote's stunt double
Jan 27, 2014
  • Jan 27, 2014
The 5.0 Thunder Bird and Cougar and Mustang will clear with no problems ,not sure what intake is on the Explorer.
rbohm
6,698
550
204
tucson,az
Jan 28, 2014
  • Jan 28, 2014
i believe the explorer intake is very similar to the mustang and tbird intakes, as well as the crown vic intake. its the F150 intake that is tall as heck.
robert fugate
103
25
39
valdosta ga
Jan 28, 2014
  • Jan 28, 2014
Yes its real similar.. Its basically a cobra copy. Thanks for the reply!
no1hedberg
33
Jan 31, 2014
  • Jan 31, 2014
According to Ron Morris Performance who specializes in EFI conversions the stock 87-93 5.0 intake is 11 inches tall. The 94-95 intake is 9.5 inches tall. The 95-01 Explorer intake is 11.5 inches tall. I would assume the tubular GT-40 and the 93 Cobra would be similar in height to the Explorer intake as they are identical inside. I have seen plenty of pictures of people using different variations of the gt40. I don't know how much spacer you need, efi short valve covers should aleviate the need for a spacer. Maybe if you run in to problems with the 1 inch spacer you could try a 1/2 inch. I hope this helps.
robert fugate
103
25
39
valdosta ga
Jan 31, 2014
  • Jan 31, 2014
1" is the smallest we can run with the valve covers.. were gonna go for it and see. Thanks for the replys
robert fugate
103
25
39
valdosta ga
Feb 1, 2014
  • Feb 1, 2014
no1hedberg i just re-read you post.. not sure you understand. I was asking if we would have clearance issues with the hood being the intake would be 1" higher then stock
no1hedberg
33
Feb 7, 2014
  • Feb 7, 2014
I'm not sure about the fit, that's why I quoted the info from Ron Morris. I guess what I was getting at is if you get it in there and it doesn't fit under the hood one option would be to use shorter efi valve covers, and take the spacer out to get a little extra room to clear the hood.
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
Clearance
  • 1993mustang50
  • Apr 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 4, 2026
2000xp8
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
