Engine 306 oil leaks!
Btw, the thread title has struck my funny bone. I thought 306 oil leaks might be about a normal air cooled engine or someone’s custom oil pan. It’s also a good starting line for a parody of 76 Trombones. Professor Hill becomes a mechanic in the sequel musical to the Music Man.
Have the PCV lines been cleaned out, and have you found the leak?
Cold 60 psi is good, warn at ldle should be around 25 psi , 40-50 psi cruising around. HV pumps are a waste of HP! Unless you have had the oil ports on the engine and heads enlarged, it's only going to move so much oil. 302 have IMHO always had great oil system feed and never seen a reason for them.
Mine was leaking in the same area. It was a cork gasket on the back of the lower intake. It looked like it had shifted on install. Got a gasket kit with the silicone front and rear gaskets and solved the oil leak.
Took out the screen underneath pcv valve and cleaned it. It was pretty bad so hopefully this week I'll grab an inspection mirror and find leak
