iskwezm
mine tooJimmys66 said:Were speaking the same language just using different words.
it had some magic worked on it and yes, it is now a 830.
12sec67 said:10SECGOAL keeps telling to buy this book he purchased about carbs from summit racing because he wanted to know everything about everything- like he usually does...
you could be too...
06cobra said:Refresh our memory please, which book?
Try putting in the jet size that Holley recommends for the primarys, then make a few full power strip runs, pull the plugs and then decide what size jets are needed to bring it to a proper mixture and jet up or down on the secondaries.69Rcode_Mach1 said:I went with a 750 with mechanical secondaries on my car, cause it does give you more power if you tune it properly. Plus with my combo it will give me room to grow when I throw in a huge cam and Vic Jr. Intake so I won't get a bottleneck effect up top. Unfortunately I don't know squat about tuning a double pumper. Which is why I keep fouling the plugs.
A 670 would be an excellant street only carb, it would just throttle that 347 some on the top end. Might be better with a 770 in that regard, the primaries would only be slightly larger and that's where you stay mostly on the street ( provided you've got control over your right foot) On the other hand, three-two's would be perfectjcode68 said:Just adding my 2 cents
I got a 347 from CHP with AFR 185's, RPM Air Gap and ~9.5:1 compression. CHP suggested the Holley Street Avenger 670 carb with vaccum secondaries as hitting right in the sweet spot given the car will be mostly street driven. I haven't purchased the carb yet, but will be soon, that is unless this thread changes my mind. Damn opinions
D.Hearne said:Try putting in the jet size that Holley recommends for the primarys, then make a few full power strip runs, pull the plugs and then decide what size jets are needed to bring it to a proper mixture and jet up or down on the secondaries.
