331 stroker what exactly is it
  • Thread starter Thread starter feifong
  • Start date Start date Apr 13, 2006
feifong
319
mesa
Apr 13, 2006
  • Apr 13, 2006
Wondering what and how i can make a 331 stroker what needs to be done to the motor exactly yes im a real noob. The mechanic says theres too much wear on the walls And i might need a new crank this was done 2 yrs ago = new pistons, rings,crank, gay internals. Never redid the heads but he says theres too much oil seepage through the rings i dont believe it but I might as well make a 331 stroker with my new h/c/i So what needs to be done to the block. It will be converted to roller btw. Where do i buy a complete rotaing assembly kit for cheap? What do you reccomend to go with my 165 61cc afr's trickflow stage 1 cam, airgap intake. Should i just buy new rings or go the whole way? thanks for the help
TrickStang37
292
  • Apr 13, 2006
wow that looks like a mess! well, to make it a 331 your gonna have to pull that motor out. then buy a kit. and finally hand it over to professional. if there is too much wear on the walls, it will need to be bored over .03-.04 unless its so worn it needs to go past that, then it would be recommended to get another block. As for making it a 331, most stroker kits you would need a new crank/pistons/rods among other small parts, not completely sure for 331, havent researched it in depth. You can find really cheap kits on ebay or in ads in the magazines, not sure of the quality.
looks like your looking to build a real mild setup.
squeeeg
1,905
Michigan
Apr 13, 2006
  • Apr 13, 2006
to put it simply. All it is is a 5.0 with a larger piston and a longer stroke of that piston. It involves a fair amount of machine work and usually it is a good idea to have a professional bolt it all together.
feifong
319
mesa
Apr 14, 2006
  • Apr 14, 2006
Im thinking on buying this kit my engine is out i want it done quick is this a good buy w/ my combo?
http://cgi.ebay.com/ebaymotors/BUDG...51414QQrdZ1QQsspagenameZWD1V#ebayphotohosting
J
jerryD
1,061
Gladstone, MO
Apr 14, 2006
  • Apr 14, 2006
always remember that you get what you pay for. you don't want to have to tear it apart and do it again. yes some people do have good luck with the cheaper kits, but is it worth it to take that chance? spend the few extra bucks now for the better parts that will hold up to abuse.
for the block work, if you get i beam rods then it will not need much in clearancing for the bottom of the cylinder wall. h beam will need more. other than that, the machine shop cost shouldn't cost all that much for the basic stuff.
i would reccomend getting in touch with brian at www.adperformance.com or a guy on this board that runs RnH performance i think.
xherdlr
159
Hendersonville,Nc
Apr 14, 2006
  • Apr 14, 2006
Looks like a decent kit..The lower cost is because of the Keith Black hypereutectic pistions. If you dont plan on staying naturally aspirated. Not using a supercharger or nitrous this kit should be fine.. There are a couple of ways to make a 331 but the most common is 3.25 crank, .030 overbore of the cylinder, and I cant remember the rod length. Dont forget to get the rotating assembly balanced. With the 331 I dont think you will have to notch the bottom of the cylinder.
Kelly
feifong
319
mesa
Apr 14, 2006
  • Apr 14, 2006
what about this kit is this much better? will i have any problems with this one?
http://cgi.ebay.com/ebaymotors/Ford...33620QQitemZ8055386337QQrdZ1QQsspagenameZWDVW
feifong
319
mesa
Apr 14, 2006
  • Apr 14, 2006
Ok i looked at some kits what about this one ?? For real this time i want a Go on it So i can buy it. Something that will last
http://www.adperformance.com/index.php?main_page=product_info&cPath=71_161_164&products_id=351
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Apr 14, 2006
  • Apr 14, 2006
there ya go buddy Eagle cranks and probe pistons are pretty decent. Much better than the KB Hypers you were looking at earlier.
Wow, that engine looks pretty sickly man. Get to work!
xherdlr
159
Hendersonville,Nc
Apr 14, 2006
#10
  • Apr 14, 2006
  • #10
Thats a good kit...Only thing I see is the 10.5 to 1 compression ratio... Not good for super charger.. Depending on what heads you have, that kit with the high compression, would cause you to use high octane fuel...But should run very strong....I would consider a custom cam if budget allows that would take full advantage of cubes... Do a search for custom cams, flowtech industries, I cant remember the guys name at flowtech. He can hook you up with cam and AFR heads...
Kelly
J
jerryD
1,061
Gladstone, MO
Apr 14, 2006
#11
  • Apr 14, 2006
  • #11
i would be more inclined to get the kit from brian at AD. he will work with you on choosing parts and what not for your setup. he won't try to sell you something you won't need either. stick with good name brands parts, and you really can't go wrong.
txstang84
1,639
42
69
Tuscola, tx
Apr 14, 2006
#12
  • Apr 14, 2006
  • #12
Eagle-good name, but just make sure you have a block that can clean up with 0.030" overbore. I've got a std bore roller block with a set of mexican main caps installed (block needs line honed) that I've already clearanced for a stroker...I know I know, keep it in the classifieds...
2KsilverGT
354
Collinsville Va
Apr 20, 2006
#13
  • Apr 20, 2006
  • #13
I just ordered a kit from Coast High Performance. They are super nice kit's a are very affordable. A 331 for under900 bucks. Just make sure your cylinders are in good enough shape to order a .30 kit. If your cylinder walls are super bad you may have to go more and more overbore.
Modular2v
3,222
23
99
oklahoma
Apr 20, 2006
#14
  • Apr 20, 2006
  • #14
i had to have my block notched for the rods to clear and spent about 400$ in machining work total
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
Motor given to me and I’d like to rebuild it what do I need to do
  • Creomod
  • Dec 14, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 16, 2024
AeroCoupe
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
