  • 1994 - 1995 Specific Tech
331 vs 347???
  • Thread starter Thread starter meansn95
  • Start date Start date Oct 18, 2006
M
meansn95
63
rowland hts ca
Oct 18, 2006
  • Oct 18, 2006
hey guys i know what would be better to turbo????why??thanx:SNSign:
gcomfx.com
3,690
Republic, MO
Oct 18, 2006
  • Oct 18, 2006
If you know... then tell us.
Black95GTS
1,644
Marlborough, MA
Oct 18, 2006
  • Oct 18, 2006
That being said, if you use the search button, you'll find so much information on this you'll vomit.
I'll also be the first to turn you on to www.turbomustangs.com
Adam
310stanger
170
  • Oct 18, 2006
naturally aspirated always go 347, turbo id go with the 331. try using the search as this has been asked so many times.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 18, 2006
  • Oct 18, 2006
But in reality neither are "better" with a turbo but the bigger engine has the capability to make more power at a lower rpm.
If I was building a turbo 302 based engine, it wouldn't be a 331 or a 347, it would be a 363" dart block (same stroke as a 347, just a much bigger bore)
Y
yellow1995Cobra
2,959
Massachusetts
Oct 18, 2006
  • Oct 18, 2006
331 sounds cooler
Killercanary
The car that set the bar.
Altoona, PA
Oct 18, 2006
  • Oct 18, 2006
If you are going to using a T4 flanged turbo, I think the 331 is the better route. A 347/363 and a decent sized turbo will be close to maxing the flow of the T4 exhaust housing and will cause some extremely high back pressures between the combustion chamber and turbine wheel.
Z
zZsKyZz
503
Oct 18, 2006
  • Oct 18, 2006
He uses too many big words.
Rick 91GT
Mustang Master
95
99
PA
Oct 19, 2006
  • Oct 19, 2006
I agree with Paul on this, but a the little extra stroke will help spool the turbo. In the end it really depends on the EXACT combo and intentions, I'm a fan of the 363 that Mike mentioned
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 19, 2006
#10
  • Oct 19, 2006
  • #10
The 331 piston has more piston material.
A 331 is a "better" option in my opinion.
M
meansn95
63
rowland hts ca
Oct 19, 2006
#11
  • Oct 19, 2006
  • #11
thanx guys:SNSign:
N
New member
  • Neokeith7
  • May 2, 2026
  • The Welcome Wagon
The Welcome Wagon May 2, 2026
nickyb
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
C
347 advice
  • CRonaldo773
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
2000xp8
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
