347 Hp Estimate?
  • Thread starter Thread starter sixfeetunder6720
  • Start date Start date Mar 17, 2016
First Prev 2 of 2
sixfeetunder6720
Active User
Dec 29, 2015
11
#21
  • Mar 21, 2016
  • #21
A5literMan said:
You're going to need all of that and a lot of compression to get 450rwhp out of a 347. 450rwhp is a tall order. You can get to around 375-400 with just a better intake and a 205cc head and reuse your cam etc. It should peak in the 6-6300rpm range. If you're going to make a max effort stock block that's the direction I would use. If you went the solid cam/shaft rockers-225cc head, you would have to shift that at a very high rpm(72-7500+rpm). Stock blocks do not like high rpms and will eventually break.
You could just throw a small nitrous kit on and make 450 easy.
Another serious question:
Is it mainly the power that kills these blocks or the RPMs required to get to said power NA?
Just wondering how safe bumping up to 450 with nitrous would be. Because id imagine i would still be able to keep the RPMs below 6500 with a kit and get the job done that way
Sent from my iPhone using Tapatalk
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,948
5,824
213
Mar 21, 2016
#22
  • Mar 21, 2016
  • #22
The girdle on my stroker is so that, maybe, when my block splits I might be able to save the rotating assembly. Still wish I would've built a SHP block but..... you live and learn.
sixfeetunder6720
Active User
Dec 29, 2015
11
#23
  • Mar 21, 2016
  • #23
Well looks like i built myself a time bomb. Great
90sickfox
Mar 2, 2015
6,948
5,824
213
Mar 21, 2016
#24
  • Mar 21, 2016
  • #24
Guess it depends on how hard we run our motors. I'm in the process of going turbo 331 on a stock block. I know a couple guys that run decent power on stock blocks with no problems. In my defense I do have a Mexican block. Some say its the harmonics from high rpm runs. I won't be pushing mine like that. My trans will blow first....gotta have a t5 fuseable link. Lol
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 21, 2016
#25
  • Mar 21, 2016
  • #25
A girdle does nothing more than help hold your broken parts in the pan. On a stock block, I don't understand putting high dollar reciprocating parts in that are rated higher than the block.
Save up your money for high dollar crank, pistons when you get a Dart block.
Reactions: 90sickfox and A5literMan
sixfeetunder6720
Active User
Dec 29, 2015
11
#26
  • Mar 21, 2016
  • #26
Lol ill be running a 4cyl t5 behind mine until i get my Gforce t5 built on the side and swapped in. So needless to say no hardcore driving for me for a little bit
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Mar 22, 2016
#27
  • Mar 22, 2016
  • #27
Rpms over 6500 and/or power levels around 450-500rwhp seems to be the accepted limits of the stock block. The block will live at those points but only for a limited time(really depends-some last a few years...some blow up fairly quick).
90sickfox
Mar 2, 2015
6,948
5,824
213
Mar 22, 2016
#28
  • Mar 22, 2016
  • #28
Wish I got that advice a few years ago.
evolven
11
San Diego
Mar 24, 2016
#29
  • Mar 24, 2016
  • #29
340 or so. Looks good.
Sent from SPACE
First Prev 2 of 2
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
L
Whats a safe limits to take this engine to?
  • LCATGA
  • Sep 3, 2024
2005 - 2014 S-197 Mustang -General/Talk- Sep 5, 2024
89ripper
