347 intake recommendations
  • Thread starter Thread starter Dmarstroker
  • Start date Start date Feb 3, 2010
First Prev 2 of 2
89stang1
Stroked and Juiced
730
234
74
nj
Feb 4, 2010
#21
  • Feb 4, 2010
  • #21
im willing to bet if u searched 100 N/A 331 and 347 u would find 30lb injectors by a landslide
matador91
107
31
38
Bothell
Feb 4, 2010
#22
  • Feb 4, 2010
  • #22
Not sure if its been said but the RPM II intake should give you some good gains
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Feb 4, 2010
#23
  • Feb 4, 2010
  • #23
89stang1 said:
Trust me
Nope, I'll go on trusting legitimate numbers and calculations over those sentence composition skills of yours. Here is that "leg work" you let me do on my own. This was the first relevant result I could come up with just by google-ing "EFI 347 MAGAZINE":
Edelbrock RPM II EFI Intake - Muscle Mustang & Fast Fords
And I quote:
MM&FF said:
The three components were swapped on the engine dyno with the motor still warm from the previous baseline testing with the stock components. Off came the stock 5.0L heads, cam, and GT-40 intake, and on went the RHS heads, XFI cam and RPM II intake. The Accufab throttle body was carried over, as were the 36-lb/hr injectors, FAST management system, and Hooker headers.
Once tuned to perfection, the 347 pumped out 448 hp and 420 lb-ft of torque. Note that the peak torque value only increased from 401 with the stock components to 420 with the new combo, but the big news was the shift in the torque curve. The 347 produced peak power at 4,700 rpm and peak torque at 3,300 rpm with the stock components, but these numbers jumped to 6,200 rpm and 5,200 rpm with the new heads, cam, and intake.
448 crank HP would be roughly 390-400 RWHP. Sound familiar?
DMAR, I know this is starting to look like a derail, but I think I've killed two birds with one stone. Check out that article... Looks like they are doing good things with the Eddie RPM II.
giddyup306
3,041
Feb 4, 2010
#24
  • Feb 4, 2010
  • #24
The RPM II is a great intake. I had mine flowed with my heads and it flowed well over 260 CFM on the intake side. At a little over 2 hp/CFM that's over 550hp on a normally aspirated 347. The bottleneck in this case is actually the heads (I had them flowed separately), so the intake should flow more.
89stang1
Stroked and Juiced
730
234
74
nj
Feb 5, 2010
#25
  • Feb 5, 2010
  • #25
And I quote:
dude your a nice guy im not looking to haggle with u .........all i can say is instead of quoting mag. articles check 331 and 347 N/A stangs here on this forum i still say u will find the most using 30lbers
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Feb 5, 2010
#26
  • Feb 5, 2010
  • #26
If you don't want to "haggle" with me, then why do you keep challenging my statement without actually providing real evidence to support your argument? I usually do try to be a "nice guy", but it really tests my patience when someone tries to debate something I say just because they can, not because they have relevant, factual information to share. So far, I've provided an actual injector size calculator and a real-life N/A 450HP 347. You've provided nothing but an argument.
So, the engine builder(s) and tuning expert(s) that built that engine don't count as a credible source?
Even if you did find an example of this, I would be willing to bet none of them are making "400RWHP and higher" as you stated above. But again, I invite you to come up with real evidence to support your argument.
89stang1
Stroked and Juiced
730
234
74
nj
Feb 5, 2010
#27
  • Feb 5, 2010
  • #27
challenging u lol.......i have 30lbers and i have freinds with 331 and 347s N/A using 30lbers making around 400RWHP.........im gonna stop wasting my time and challenging u ........use your little real life calculator YOUR RIGHT! LMAO!!!!
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Feb 5, 2010
#28
  • Feb 5, 2010
  • #28
how about this? http://www.stangnet.com/mustang-forums/778647-proper-fuel-pressure-30lb-injectors.html
Dmarstroker
116
Vancouver, WA
Feb 5, 2010
#29
  • Feb 5, 2010
  • #29
Jaym14 said:
ever consider a performer RPM II?
And I quote:
Sounds good I totally forgot about the eddie rpm 2 intake I'll take that intake into consideration for sure now, thanks.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Feb 5, 2010
#30
  • Feb 5, 2010
  • #30
I have had both the RPM II and trick flow R, both awesome intakes, dont be afraid of it being lazy in the lower RPM's with a bigger intake, the cam will be more responsible for where it makes power then the intake. Just a heads up, if you plan on going bigger in the future with the heads, get the R.
I had every intention of using my RPM II but when i matched up the gasket from the new head there was so much material to be removed that it was getting into the injector bungs. So keep that in mind.
Also, sure mabye you could run 30# injectors at the HP level your talking about but you dont want to run an injector over 80% duty cycle if you dont have to, just get 42's, there everywhere, you could get them used for 200 bucks im sure, and then you have nothing to worry about, there wont be any drivability loss between 30# and 42#. If you were talking about putting 60#ers on the car then you might have a tuning issue.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Feb 5, 2010
#31
  • Feb 5, 2010
  • #31
This post dosent help your argument
jrichker said:
Injector HP ratings: divide flow rating by .5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
304 HP x .85 = 258 HP
385 HP x .85 = 326 HP
480 HP x .85 = 408 HP
So with this logic, a 30lb injector is running about 92% duty cycle at 440 hp, the reccomended duty cycle is 80%, so a 36lb injector would be between 75 to 80 percent at 440 hp, which would be perfect
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Feb 5, 2010
#32
  • Feb 5, 2010
  • #32
Thanks, 90lxcoupe. Good to see I'm not the only crazy one here.
gt40_2003wes
Aug 14, 2005
461
ky
Feb 5, 2010
#33
  • Feb 5, 2010
  • #33
i was on his side in the argument i think my question mark made it sound different lol. i posted that so he would have another article besides a magazine to go with lol.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Feb 5, 2010
#34
  • Feb 5, 2010
  • #34
Ha, OK then. Welcome to the club of sound reasoning.
matador91
107
31
38
Bothell
Feb 5, 2010
#35
  • Feb 5, 2010
  • #35
kind of suprised that this car and article hasn't been brought up. shows different intakes and the gains with the help of a throttle body upgrade.
http://www.musclemustangfastfords.c...mustang_cobra_project_stolen_goods/index.html
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Feb 5, 2010
#36
  • Feb 5, 2010
  • #36
1993 Ford Cobra Mustang - Project Stolen Goods - Muscle Mustangs & Fast Fords Magazine
You're right, I forgot about that car. I actually have the mag with the engine specs sitting right next to me now. That car only makes 372 RWHP, and it uses 38 lb/hr injectors.
Dmarstroker
116
Vancouver, WA
Feb 9, 2010
#37
  • Feb 9, 2010
  • #37
thanks for the link.
Has anyone had experience with the efi victor jr spyder intake ?
I searched all over google and I searched some forums as well but they all said that CHP does not make them any longer.
fiveohwblow
Official Member
2,169
145
155
Feb 9, 2010
#38
  • Feb 9, 2010
  • #38
fiveohwblow said:
There is a LARGE difference when choosing injector size and utilizing boost or cubes to get you there. With N/A you need much less. I think maybe what nikwoa was trying to say was you might be at maximum duty cycle on those injectors with 400 rwhp. Never would hurt to go 36's or 39's.
On to other things, I have made what I wouldnt consider "well" over but a pretty decent amount over 400 with a home ported cobra. It can be done and I agree with 89stang1 that the torque and power curves are relatively flat and gorgeous with this intake.
I was with ya all along buddy!
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Feb 9, 2010
#39
  • Feb 9, 2010
  • #39
Ha, yea I wasn't directing that at you. I guess I should have said, "nice to know we aren't the only crazy ones here".
First Prev 2 of 2
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
