351 2v to 4 bbl
  • Thread starter Thread starter mymach
  • Start date Start date Sep 20, 2006
M
mymach
12
Easthampton
Sep 20, 2006
  • Sep 20, 2006
Hi,
I have a 1970 Mach1 w/351 C 2v only mod is headers. Had the car since 1978 and it is my pride and joy for sure. Two questions if anyone is interested.
1. I always had a problem with the engine starting very sluggishly when hot. Sounds as if the battery is weak. The last time I went in for a sticker, shut her down for 5 minutes and when the sluggish starting was ocurring, I noticed the positive battery cable was glowing red! Could this be due to a bad ground? Starter? or are these cleveland motors notorous to swelling in the piston/combustion chamber.
2. Just purchased an autolite 4100 from pony carbs. also purchased a edelbrach performer 4 Brl manifold for the 2v motor. Can I expect a decent increase in performance over the 2 brrl autolite at present? Anything I should be aware of?
THANKS!!
G
Gud T.B. Blown
583
Sep 20, 2006
  • Sep 20, 2006
As to question #2; yes, you will see a noticeable increase in power. And you shouldn't expect anything as far as intallation goes, it should be pretty much straighforward. Just make sure you still get the appropriate intake gaskets for a 2V engine.
69 Rustang
307
Orange County California
Sep 21, 2006
  • Sep 21, 2006
Question #1: Both of my Clevelands do the exact same thing on hot starts. Cooling down a while and they start fine. I am getting ready to put on new cables and re-check the timing. Looking forward to other replies.
Max Power
1,774
St Paul
Sep 21, 2006
  • Sep 21, 2006
I would research a permanent magnet starter for your Cleveland. It's great for cars with headers and heat soak.
D
D.Hearne
11,730
south louisiana
Sep 22, 2006
  • Sep 22, 2006
You need new cables, (bigger the better) and a starter with NEW high torque field coils. Some are fans of Autolite carbs, but I've found them always difficult with hot starts.
dodgestang
1,360
Cecil County, MD
Sep 22, 2006
  • Sep 22, 2006
Heat shield is missing around the starter most likely and if you are using the stock starter replacing it with a high torque will fix the problem. You also won't need to add back the heat shield then most likely. I run a mini starter with long tubes on my 351c and have had no issue.
D
darkhorse70
95
Austin, TX
Sep 29, 2006
  • Sep 29, 2006
I agree with D. Hearne -- if the battery cable is getting hot, it means the connection where it heats up has too much resistance, meaning a bad connection. Maybe you just need to clean the battery contacts, but most likely the connection between the battery cable wires and the battery terminal connector is corroded or damaged. Put on some new heavy-duty cables and your starting problem and hot cable problem should both go away.
RogerC62
833
11
38
Dayton, Ohio
Sep 29, 2006
  • Sep 29, 2006
Q1. I've always had that problem with mine. It seemed to have an issue with vapor-lock (heat soak through the intake). The other suggestions will definately help though since your cable is getting hot.
M
mymach
12
Easthampton
Sep 30, 2006
  • Sep 30, 2006
Thanks '73! Sorry about the late acknowledgement. I'm new to this site and didn't think I was posting correctly. I'll be in touch!
mymach
M
mymach
12
Easthampton
Sep 30, 2006
#10
  • Sep 30, 2006
  • #10
Thanks Dave! looks like we received some great replies!
M
mymach
12
Easthampton
Sep 30, 2006
#11
  • Sep 30, 2006
  • #11
THANKS D.!
As I mentioned to '73, sorry about the late reply, I didn't think I was posting the question correctly (being new to the site) and didn't check back enough times. I appreciate the input and let you know how things work out.
GREAT SITE!!! I'll be in touch!
mymach
M
mymach
12
Easthampton
Sep 30, 2006
#12
  • Sep 30, 2006
  • #12
351 2v to 4v hot starts
APPRECIATE THE REPONSE! sORRY FOR BEING LATE WITH THE ACKNOWLEDGEMENT. Didn't think I was posting correctly.
I'll let you know how things work out!
THX!!
mymach
M
mymach
12
Easthampton
Sep 30, 2006
#13
  • Sep 30, 2006
  • #13
THANKS darkhorse!
I appreciate the reply and suggestions. Will let you know how things work out!
mymach
M
mymach
12
Easthampton
Sep 30, 2006
#14
  • Sep 30, 2006
  • #14
THANKS RACERX!
Appreciate your response! Looks like I have some things to run with. This is great!
THANKS!
M
mymach
12
Easthampton
Sep 30, 2006
#15
  • Sep 30, 2006
  • #15
THANKS MAXPOWER!
M
mymach
12
Easthampton
Sep 30, 2006
#16
  • Sep 30, 2006
  • #16
THANKS NICK!!!
D
D.Hearne
11,730
south louisiana
Sep 30, 2006
#17
  • Sep 30, 2006
  • #17
One generic reply would have sufficed No need to bend over backwards here.
F
For Sale 1973 Mustang convertible 351C w/ mods | NJ, NYC area
  • fvc496
  • Feb 17, 2019
  • Classic Mustangs For Sale
3K
Classic Mustangs For Sale Feb 17, 2019
fvc496
F
351 c 2v to 4v head swap?
  • black95gts5.0
  • May 11, 2009
4K
Classic Mustang Specific Tech May 13, 2009
71stangfreak
M
351c 2v 4brrl conversion
  • mymach
  • Sep 14, 2006
  • Regional Forums and Event Information
Regional Forums and Event Information Sep 14, 2006
mymach
M
C4 to AOD swap
  • jlangholzj
  • Mar 22, 2009
32K
Classic Mustang Specific Tech Apr 13, 2009
jlangholzj
