351 alternator wiring
  • Thread starter Thread starter OonDeanisS
  • Start date Start date Apr 26, 2007
OonDeanisS
902
Danbury, CT
Apr 26, 2007
  • Apr 26, 2007
these are my alternator wires, can anyone tell me where this red wire goes?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 26, 2007
  • Apr 26, 2007
Wha year car? What kind of car? There are no clues in your post.
OonDeanisS
902
Danbury, CT
Apr 26, 2007
  • Apr 26, 2007
its an 86 4cyl notch with a 74 351w stuffed in
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 27, 2007
  • Apr 27, 2007
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model Mustangs
Mustang78
486
Aberdeen, WA
Apr 27, 2007
  • Apr 27, 2007
i believe the L shaped one goes to your temp sensor on top of the intake, and the othewr 3 to the back of your alt., the big red one screws on and the other 2 push on, they are color coded on the back of the alt.
~Mark~
OonDeanisS
902
Danbury, CT
Apr 27, 2007
  • Apr 27, 2007
o ok, i dont think i have that temp sensor... i have a mechanical water temp gauge
Mustang78
486
Aberdeen, WA
Apr 27, 2007
  • Apr 27, 2007
so just dont use it..or cut the plug and tape everything up for a cleaner look. also verify that plug IS in fact the temp sensor wire, if there is another one just like it then it could be your oil pressure wire, etc..
~Mark~
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 27, 2007
  • Apr 27, 2007
Check the wire color and the stripe on the wire. There are 3 possiblites:
Temp sender
Oli pressure sender
Starter solenoid to ignition switch control (turns the solenoid on to power the starter when you turn the key to Start)
Use the link to the Autozone wiring diagrams and check the 3 circuits mentioned for wire colors. When you find a match for the base color and tracer stripe from the 3 choices, you will know what the wire does.
OonDeanisS
902
Danbury, CT
Apr 28, 2007
  • Apr 28, 2007
theres no stripe, just a solid red wire.... i still have trouble reading the wiring diagram sorry...
C
cookracing
#10
  • Apr 4, 2009
  • #10
that L shaped red wire goes to your starter solenoid the origional solenoids only had 3 posts 2 big ones and one small one a replacement will probly have 4 posts two big and 2 small the 2 small post should be labeled one with an I and the other with an S that wire plugs onto the one Labeled With an S hope this helps
Resolved 83 alternator wiring harness
  • sparten5000
  • Aug 2, 2026
Fox 5.0 Mustang Tech Aug 23, 2026
limp
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
