On a 351c, does the PS belt go from crank to PS pump or also around the water pump pulley? The crank pulley and the PS pulley have a 1/2" groove, the double groove water pump pulley has 2 3/8" grooves, one is for the alternator. Even though they line up, I'm thinking it's direct to the pump, not using the water pump pulley since doing it that way has a constant squeal that no amount of adjusting or new belts will cure. Thanks
