- Mar 30, 2005
- 388
- 0
- 0
vristang said:I am.
Is that your only question?
jason
EDIT: You do mean a Windsor, right?
vristang said:The 351w sits in the same location as the stock 302. The same motor mounts and trans/bellhousing are used.
The industry standard is for the swap headers to bolt up to a factory 302 mid pipe. I have not seen any headers that did not follow this standard.
I am using mac unequal shorties. I have no complaints, but others have declared that they do not fit as well as the more expensive brands.
I have a pretty detailed article on my website on the 351w fox body swap. There is a link to the site in my sig.
Let me know if you have more questions.
Are you planning the swap now?
jason
blackcloud50 said:I'm aware that the 351 sits in the same location as 302. I was just wondering in your particular application did you use an aftermarket K-member that maybe lowered the motor or set it back to get the headers to connect to factory 302 midpipe.
So do the headers have to be labeled "swap headers" to be able to use factory midpipe or will any 302 shorty header work just fine? I was looking into getting a 1 3/4" shorty possible from AFM but not sure if I can use them because they do not mention they are for 351 swap. Also do you know of any other manufacturer that makes 1 3/4" shortys?
86bluecobra said:looks like i may be wrong. I searched everywhere all i see is 1 5/8 shorty swap headers.
86bluecobra said:i believe vristang is using 351w swap headers.
blackcloud50 said:vristang, what heads are you using?
