351w 1969 stop runing
  • Thread starter Thread starter scrrewchamp
  • Start date Start date Oct 12, 2010
scrrewchamp
11
laurel md
Oct 12, 2010
  • Oct 12, 2010
351w was running great then it started to pop then shut down checked coil cap put new electronic in cap it will start but wont stay running and it is rough when you give it some gas it stalls out can any one help
Az Pete
711
18
49
Panama City, Fl.
Oct 12, 2010
  • Oct 12, 2010
Have you verified the cam and valve timing. Sounds like the timing chain may have jumped.
F
fst64_v8pwr
9
  • Oct 12, 2010
Ooo not a good thing. Good luck
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Oct 12, 2010
  • Oct 12, 2010
That's a good indication!
scrrewchamp
11
laurel md
Oct 12, 2010
  • Oct 12, 2010
I have a feeling it could be something like that it pop and idles like the timing is off .
Thanks I will check it out .also where can i get a timing pointer for a 69 351w this one wasnt put on I got one from cj pony but it looks to small.
scrrewchamp
11
laurel md
Oct 12, 2010
  • Oct 12, 2010
damm
65coupe408w
192
  • Oct 13, 2010
+1 for timing issue
scrrewchamp
11
laurel md
Oct 13, 2010
  • Oct 13, 2010
I checked the timing the #1 piston and rotor on #1 was good iam thinking n=maybe a electrial or drop a vaule can any one help
68RCodeConv
345
Houston, TX
Oct 14, 2010
  • Oct 14, 2010
Pull the valve covers and check all the rocker arms for looseness.
scrrewchamp
11
laurel md
Oct 18, 2010
#10
  • Oct 18, 2010
  • #10
still runing very bad 351 w
Iremoved the covers all looked good pulled the plugs they looked fouled changed them still runs like it s out of time could it be the distribtor geers inside ?
woodsnake
1,352
15
69
Hicksville, NY
Oct 19, 2010
#11
  • Oct 19, 2010
  • #11
While you had the valve covers off, did you give the push rods a spin with your fingers? If they are bent, they will be a lot looser than if they are still straight. If you have a helper, have them crank the engine, while you have the valve covers off, and see if they all move the same....
67rcks
373
Oct 20, 2010
#12
  • Oct 20, 2010
  • #12
if it responds to gas what about your carb? soaky floats? stuck electric choke?
scrrewchamp
11
laurel md
Oct 20, 2010
#13
  • Oct 20, 2010
  • #13
found the problem
pulled the distributor and it broke 3 teeth off and 2 on the cam
69gmachine
576
Southern Maryland
Oct 20, 2010
#14
  • Oct 20, 2010
  • #14
Now you need to find out what caused the distributor to lock up. It could be internal to the distributor, or the oil pump could have locked up, or the cam locked up (least probable).
65coupe408w
192
#15
  • Oct 20, 2010
  • #15
also keep in mind that you need to have the correct type of gear on the distributor. If you have one made from the wrong material the cam will eat the teeth off. In this case it sound more like something siezed though...
scrrewchamp
11
laurel md
Oct 20, 2010
#16
  • Oct 20, 2010
  • #16
rebuild
Help need help on rebuilding I have a 1500 sq ft shop with lift but I have health problems can anyone help out ?
silver66pony
22
#17
  • Oct 20, 2010
  • #17
what is your location
woodsnake
1,352
15
69
Hicksville, NY
Oct 21, 2010
#18
  • Oct 21, 2010
  • #18
Sorry to hear that. Twisted oil pump drive shaft? Let us know when you get a final autopsy performed..
scrrewchamp
11
laurel md
Oct 21, 2010
#19
  • Oct 21, 2010
  • #19
laurel maryland
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sep 26, 2026
AlexM556
A
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
