351W Plug Wire Diagram Needed
tripwire1969
Just need to know where there's a pic to go by, so I can get my 70 back in running order. Seasrched the web, and no luck...hard to believe. This is for the plugs to the cap (I have Duraspark distributor). Thanks!
ok, i dont have a pic for you, but its simple. the 351W firing order is 1-3-7-2-6-5-4-8 So you find the number (1) on the distributor cap and hook it up to cylinder 1. the cylinders are numbered from front to back. so the passenger side is 1-2-3-4 and drivers side is 5-6-7-8 from radiator to firewall. then you just work your way counterclockwise or to the left around the distributor following the firing order above. hope this helps. if i had a scanner, id send you the picture i have of this in a chiltons manual.
