  • 1994 - 1995 Specific Tech
4.10 install question
  • Thread starter Thread starter 94_5.0
  • Start date Start date Jan 16, 2004
9
94_5.0
337
Jacksonville, NC
Jan 16, 2004
  • Jan 16, 2004
with 4.10s what can I do to recalibrate the spedo besides a new spedo gear? and if all I can do is a speedo gear what one do I need?
gunslinger8200
41
Wisconsin
Jan 16, 2004
  • Jan 16, 2004
you can get a speed cal from dallas mustang. It fixes the signal to the speedo to make it read the correct speed. Here's a link http://www.dallasmustang.com/index.mvc?Screen=PROD&Product_Code=9910&Category_Code=
mytight95
2,605
Dothan,Al
Jan 16, 2004
  • Jan 16, 2004
If you change the gear on the output shaft to a black 6 tooth drive gear it will be dead on.
if you don't know what it looks like i could take a pic of one for you
jason
9
94_5.0
337
Jacksonville, NC
Jan 16, 2004
  • Jan 16, 2004
how do I change the gear on the out put shaft, and where can I get one?
As for the Speed cal they will not work( I called DM and verified this) on our year car we still have mechanical spedos.
randomjoker
427
Oklahoma
Jan 16, 2004
  • Jan 16, 2004
Yeah if you notice on the web site that you supplied.
Fits Model Years: 1996 thru 2000
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 16, 2004
  • Jan 16, 2004
Can't remember if its here or the Corral but I think I've seen a detailed post on the drive gear change out in the tail shaft section.
Should not be too hard to find with a search.
Later
Grady
mytight95
2,605
Dothan,Al
Jan 16, 2004
  • Jan 16, 2004
the speedcal WILL work!!!!! many people on here have ordered it, and still use it. Our speedos have machanivally driven gears connected to a sensor, which in turn spins the sensor and tells how fast the car is going. When you splice in the speedcal, it does the same thing that it does in the 96 up cars. The output gear can be changed by removing the extension housing on the tranny and changing the drive gear. it is the gear that turns the gear on the sensor. pretty straightforward, you can do it with the tranny in the car but it is easier to do it with the tranny out, also gives you a good chance to check the preload on the factory gearset, to see if it is within specs
jason
jmuva44
1,338
Richmond, VA
Jan 16, 2004
  • Jan 16, 2004
If it doesnt have to be exactly perfect but can be a few miles per hour off, just changing the main speedo gear to a red #23 is supposed to be the easiest way. I myself have an Abbott box which calibrates mine to the mile per hour.
9
94_5.0
337
Jacksonville, NC
Jan 16, 2004
  • Jan 16, 2004
where do you splice the speed box into and hoe does it work? Also I have heard the the drive gears break really easly..is that true and what would be the most accurate way to do it?
mytight95
2,605
Dothan,Al
Jan 17, 2004
#10
  • Jan 17, 2004
  • #10
the drive gears chew the teeth off when you use that 23 tooth b/c it is not a ford product, and they dont mesh well, you can call a tranny shop etc. and they will tell you the best way to do it without splicing wires etc. is with the drive gear being a 6 tooth. Go to hanlon motorsports, or steeda or D&D motorsports, on the web and look up some speedo charts you will see what i mean.
jason
9
94_5.0
337
Jacksonville, NC
Jan 17, 2004
#11
  • Jan 17, 2004
  • #11
so If I change the drive gear to a 6 tooth and add the 23 tooth it won't chew it up?
9
94_5.0
337
Jacksonville, NC
Jan 17, 2004
#12
  • Jan 17, 2004
  • #12
what is an abbott box?
mytight95
2,605
Dothan,Al
Jan 17, 2004
#13
  • Jan 17, 2004
  • #13
if you change the drive gear to a 6 tooth, you won't need to change anything else therefore you leave the factory gear on the speedo sensor, and no mesh problems occur with the teeth of the gear
jason
GTPhreak
5,505
Rowlett, TEXAS
Jan 17, 2004
#14
  • Jan 17, 2004
  • #14
by the time you have removed the transmission to get into the tailshaft, remove and press in the new gear, you will have been just as well off $$ with a speedcal
9
94_5.0
337
Jacksonville, NC
Jan 17, 2004
#15
  • Jan 17, 2004
  • #15
so the speed cal will work with our car ....this is a for shure thing then..I judt want to shure that this will work..being like 100.00 dollars and such
mytight95
2,605
Dothan,Al
Jan 17, 2004
#16
  • Jan 17, 2004
  • #16
if you pay someone to do it you should probably get the speedcal but if you can do basic mechanics, i would change it myself
jason
jmuva44
1,338
Richmond, VA
Jan 17, 2004
#17
  • Jan 17, 2004
  • #17
You can get the speedcal from Brother's Performance for like $15 cheaper I think....FYI
Brothers SpeedCal
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
