Hey guys I have a 1994 gt convertible. I did a dash over lay and now my speedo and tach do not work I also replaced the odometer gear which does work. All fuses are good. Any one else have this problem
Yes no codesHave you checked for codes? Are you sure the wiring is 100% and the printed circuit on the back of the cluster is 100%?
As far as I can see i had to remove the needles for the glow overlayAnd what about the wiring and printed circuit?
And then put everything together and they both dont workAs far as I can see i had to remove the needles for the glow overlay
Yes I did ive had it out before with no issueHe wants to know the install procedure, like did you remove the cluster to do the install?
Was not trying be vague im in ny working at a dispensary. LolWell now you have an isssue....
You likely don't have the electrical connector pushed in all the way or a pin has slipped out, as far as the speedometer that is likely not pushed all the way on either.
You can't be vague when taking about tech issues online, we don't have crystal balls.....I mean some here may think they have brass balls and a couple I think actually do but.....you know......![]()
