4.10's in an Auto Video?
I have a question for all of the guys with 4.10's in an auto?? Where do you buy all of the other essentials you need along with the gears and also what type of gear oil do you need! What is the best type of gear oil? More Videos??
You need some friction modifier, and oil (I used same as stock). Other than that you just need a chip/tuner to fix your shifts and speedo. No big deal. A chip/tuner can do wonders for shifting and add a little power too, so its a great combo for the auto.
Jake: Can you write down ECT and TFT parameters while holding it steady at
1) 65 mph @ 2400 RPM
2) 80 mph @ 3000 RPM
Hold the speed for a good 2-3 minutes then write down the ECT and TFT. I'm curious to see how well the tranny cooler hold the temps down. I kept it steady at 3000 RPM with the stock gears (OD locked out) and the TFT shot up to 200 degrees. That's one thing that is keeping me from getting 4.10s.
Thanks.
joshheat25 said:
Propeller head when you say the temp shot up how quickly because I did this also and didn't see a change???
Really? Do you have a cooler already? I don't.
In 4th/OD going 80/2400, the TFT was steady at 185. ECT was at 196, if I remember right. When I locked out OD and dropped my speed to 70/3000, in about two minutes the TFT climbed to 200. It scared me when it went past the ECT so I quit my test.
Yea I tried the experiment today and I had OD off and was in 3rd going 60mph at about 2,600 rpms and realized that is too much rpms to cruise at I mean the engine isn't loud it just seems bad for the engine! But I was looking at my gauges and I didn't see the Water Temp rising in the upper left of my gauges??? so I dunno!
