4.6 2V Oil Requirements
I have just been using 5 quarts of 10w30 Mobile1.
But, I have noticed that some have been using 5 1/2 - 6 quarts.
I need to look at my manual to see what it says.
So far 5 quarts brings the level right up to the line on my dipstick.
I have a 2001 GT if that makes any difference :shrug:
I just did the first oil change on my '04 GT, and I used 6 quarts of Mobil 1 10W-30. Seems like the oil pressure is a tiny bit higher than it was before, but I don't remember exactly where the needle was before the change. No problems though. Manual says to use 6.
I use 5 1/2 quarts of Mobil 1 5W-30. Even though the manual says to use 5W-20, it's still okay to use 5W-30 and 10W-30 grades?
Saleen201 said:
If the manual says use 5W-20, why would you use anything else? :scratch:
-Mike
I used 5W-30 because I was used to my friend's 2000 Mustang in which the recommended oil was 5W-30. I thought that this recommendation of oil usage was carried over to 2001 (which is my model), so I had synthetic 5W-30 put in. I just recently saw in my manual that the recommended viscocity of oil was 5W-20.
I thought you ment you did it on a regular basis. The numbers represent the fluid viscosity (or resistance to flow). I dont remember specifics, but a small difference (like using 5w30 insead of the recomended 5w20) wont make a difference. I would just make sure you get 5w20 from now on, no big deal.
-Mike
