Most everyone knows the issues the 4.6 2v has had with the plastic intake manifold. The original design included a plastic coolant crossover and of course after repeated heating / cooling cycles this crossover tended to crack. Ford recognized the problem and redesigned the intake. They made the front coolant crossover aluminum. However, the "improved" manifold still had a layer of plastic between the metal crossover and the cylinder head.
My '04 GT had the original "improved" Ford design from the factory. Now and again,, only at full operating temp, I'd get whiff of coolant. No leaks. No drips. No overheating. Over the course of the Winter I lost a good bit of coolant. Still no visible leaks / drips etc. Finally ran a coolant pressure test. At operating pressure of @ 15psi I was hearing air / coolant escaping from somewhere. I was able to narrow it down to the area on the intake, LH (Driver's side) underneath the metal coolant crossover.
Note the plastic area underneath the metal coolant crossover. Thousands of heat cycles / years and it's inevitable, the plastic will degrade.
Here's a better shot of the cracked coolant port
So for all those people hoarding used intakes? Good luck with that plan.
Now we all know, for the longest time the only 'direct' replacement intake on the market was the Dorman, or one of its numerous copies. While the Dorman type does have a metal crossover, it also has plastic between it and cylinder head. Same for the Ford Performance replacement that was sold several years ago.
The new design also uses O-Ring type manifold gaskets and there are also gaskets in between the metal crossover and the plastic part below it.
Recently a new design, an "improved" (Sound familiar?) intake manifold hit the market. It is NOT a Dorman intake, it's a new casting. The company that makes these intakes Ford Performance also apparently produced / is producing them for Summit Racing as well. The Summit Racing version is IDENTICAL to the intake sold under the Ford Performance name. The ONLY difference is one has Summit Racing cast into it and the other has Ford.
Identical instructions. Identical included hardware. Identical intake. Only difference is price. The Summit version is a bit over $200. So I ordered one and installed it. I had seen some complaints / reviews regarding Coil bolts and other small hardware related things, and the instructions are ridiculously vague, since the same intake is intended as a replacement for Mustangs, Crown Vics etc.
The new intake
This version has NO plastic between the metal coolant crossover and the cylinder head.
Installed it back in February. Everything seemed fine. Recently, during a clutch replacement that turned into a K Member drop (header clearance) Noticed a slight coolant leak after. The new intake was leaking under pressure. Was able to localize it with a pressure test - it appeared to be leaking from the LH (Driver's side) rear coolant block off plate. This is a separate piece of plastic bonded into the intake itself. After pulling the intake, I couldn't find the crack / leak source....but it was definitely leaking.
So I had only a few choices. Try another "improved" intake, try my luck with a used intake, if I could find one, or hunt down an all aluminum replacement. The only new one on the market, besides the Edelbrock Victor Jr (which required custom fuel rails, plenum elbow etc) is the Speedmaster.
It's apparently a clone of the old Typhoon intake. I saw reviews of some complaints about rough port casting and some other issues with the Speedmaster, but I rolled the dice. I needed the car back on the road, and a reputable supplier had one in stock.
Got the intake installed. It uses all original hardware except for the intake manifold bolts, it provides new hardware.
Installed it with no issues. Fired up and had a massive exhaust leak. Turns out I had cracked the original EGR pipe running to the LH header. After finagling a replacement pipe into place, fired it back up and I had a massive vacuum leak. My smoke machine was MIA and went ahead and ordered one and I ordered the "problem solver" Fel Pro intake gasket set - which is metal / rubber and even has torque limiters on the gasket itself. While waiting on parts, I ran across a review of the intake where someone noted that there was a drilled / tapped bolt, right under the the throttle cable where it hooks up to the the throttle body, and it's apparently drilled into the intake runner, causing a massive vacuum leak. I installed a bolt w/ thread sealant into that hole, reinstalled the intake and the massive leak was gone. Engine ran well - but after hitting temp, it would throw Bank 1 / 2 lean codes, high / hanging idle etc.
Took it back out, and disassembled the entire intake.
These two pieces had some bolts that weren't torqued down (I should have checked - that's on me). I ended up coating both sides of both gaskets with RTV, torquing the bolts down, then I smoke tested the intake off the car. It passed.
Then I installed the metal / rubber Fel Pro intake gaskets
Fired it up - no codes / no leaks / even after the battery unhooked and no learned fuel trims, it fired right up, cold idle rock solid at 1200 RPM, fed it coolant, up to temp, idled down and ran great- no codes / trims looked good.
Will update if anything changes - hope this helps someone who might be dealing with this common 4.6 2v issue.
The new intake
