The PI heads from a 5.4 will work. I have a set I need to put on my car now. The only difference is that you will need 10mm bolts for the timing chain cover. The 4.6 heads use 8mm bolts. You may need new valve covers too. My 5.4 heads are Windsor heads. It will use the 4.6 intake also.
